RV.Net Open Roads Forum: Travel Trailers: Trailer hitch
 > Trailer hitch
Bob 66
dilley,tx
Posted: 03/24/12 07:37pm Link  |  Print  |  Notify Moderator
Just bought new TT. My hitch is sticking and hard to separate from hitch ball. They used a 2 5/8 size ball. I'm using a new progressive g-4 equalizer. Is the newness of the hitch/ball the problem. Advice needed.
chesterb
Ohio
Posted: 03/24/12 07:47pm Link  |  Print  |  Notify Moderator
This is common. You may have to drive forward slightly or sometimes I just crank it down, step up on the hitch and jump a little and it comes free. Make sure you chock your wheels first.
2011 Dodge 2500 Hemi, Crewcab, 4x4, 4.10
2013 Rockwood Mini-Lite 2306
WI Bowhunter
Shiocton, WI
Posted: 03/24/12 08:12pm Link  |  Print  |  Notify Moderator
I do the same thing. A little bouncing on the bumper of the truck works. Make sure to put some grease on the ball also. Makes things a little messy, but needs to be done.
Keep the Shiny Side Up!
2011 F150 Supercrew, 4X4 3.5 Ecoboost, 145" wheelbase, 3.73 gears, Max trailer Tow package
2014 Puma 30DBSS
Equali-I-Zer WD Hitch
3 kids and 1 DW
skipnchar
Topeka or somewhere else
Posted: 03/24/12 09:20pm Link  |  Print  |  Notify Moderator
What are you putting on the ball to lube it? Heavy grease works best. Even when properly lubed you may have difficulty removing the coupler from the ball when there is positive pressure. Try pulling slightly forward or backward (whichever direction puts the pressure to neutral).
If you back in going up hill, chock the wheels them let the tow vehicle move slightly forward to take the pressure off and do the opposite if you back in heading down hill.
Good luck / Skip
Chuck&Gail
In the Colorado Mountains
Posted: 03/24/12 09:32pm Link  |  Print  |  Notify Moderator
Good luck / Skip
Sounds right. I use Reese ball lube, or wheel bearing grease.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
tspecs
home
Posted: 03/25/12 05:46am Link  |  Print  |  Notify Moderator
Once the wheels are chocked, just remove the locking pin from the receiver/stinger, and raise the trailer. It will find it's own release point by sliding back or forward.
tspecs
APT
SE Michigan
Posted: 03/25/12 07:27am Link  |  Print  |  Notify Moderator
I usually chock the TT wheels, put the TV in neutral and let off the brake to relieve pressure on the ball.
2012 VW Passat TDI
fla-gypsy
North Florida
Posted: 03/25/12 03:00pm Link  |  Print  |  Notify Moderator
Lube up that ball and it will get easier
WI Bowhunter
Shiocton, WI
Posted: 04/06/12 06:26am Link  |  Print  |  Notify Moderator
I use regular wheel bearing grease. Of course I always keep a few grease rags around to wipe my hands off. It never fails I get some on me at some point.
froghunter
Walla Walla, WA.
Posted: 04/06/12 10:28am Link  |  Print  |  Notify Moderator
My TT (Bigfoot) uses a 2 5/16" ball, and I thought this size was standard in the industry. You mentioned that you have a 2 5/8" ball, which would for sure be a difficult fit if the trailer has the smaller coupling.
 > Trailer hitch
