mikefree5151
houston
Hi, I just purchased a 1995 Gulfstream Ultra, Class C. There is a black switch on the underside of a kitchen cabinet. It does not operate any of the lights.
I can't find the water heater switch and thought this might be it but there is no red indicator light near it so I'm not sure. Any suggestions?
CamperKirk
Bay Village
My 1999 Gulfstream has a black switch on the bottom of the cabinet by the srairs that operates the outside light. Did you check that light?
mikefree5151
houston
I did not check that - could very well be the outside light. Any idea where the water heater switch is located??
Wills250psd
walnutcove NC
My tt is a 95 and the switch is actually on the WH inside the rv. follow the power wire to the unit and mine is right there on the unit its a little flip switch. maybe yours is there. will
CamperKirk
Bay Village
My water heater switch is on the control panel above the range along with all the other switches.
rgraham
Missouri
We have a 1995 Gulfstream Fifthwheeler and the Water heater switch is on the bottom of the cabinet next to the sink just where yours is,
Richard
1987 ford f250 6.9 diesel
1997 Innsbruck by Gulf Stream 28ft fifth wheel with slide
and the wife and co-pilot Trudy
mikefree5151
houston
Well, it turns out the mystery switch is indeed for an outside light by the door. I can't for the life of me find a water heater switch anywhere inside the coach. Is it possible one does not exist?
SailingOn
Central Texas
My switch for the water heater electric element was indeed on the bottom of a kitchen cabinet, without an indicator light. Someone suggested it was put there so kids would not play with it. The placement can be irritating, since the WH is a fairly large current draw and you'd like to be sure that it is on or off.
If you remove the switch from the cabinet and put a voltmeter across it, you can test it by turning circuit breakers on and off; maybe the breaker that matches will be labelled "water heater".
I moved mine to a more visible location, and substituted a lighted-when-on rocker switch.
mikefree5151
houston
rgraham, does your water heater switch have a red indicator light? The switch under my cabinet does not and that is why I'm not sure.
rgraham
Missouri
mikefree5151 wrote: rgraham, does your water heater switch have a red indicator light? The switch under my cabinet does not and that is why I'm not sure.
Yes it has a rocker switch and red indicater light it will come on when you turn it one way you can hear the burner light on the water heater when it get up to temp the light goes off,this is for gas only
