Sprinks542
Western Pa.
Can anybody steer me in the right direction on what tires would be a good replacement for me? Tires now are Carlisle ST/8016. Did the search button without much luck.
08 Ford F-350 SD PSD CC
10 322 Fuzion Touring Edition II
07 Can-Am Outlander 800
08 Can-Am Renegade 500
Georgew48
Ohio
I replaced mine with Goodyear G614. A little expensive but I have over 10,000 miles on them and the only problem I have is a little wear on the inside of my left rear tire from an alignmenmt problem. They are G rated 12 ply tires that run at 110 psi. You wheels should be the same as mine and will support the 110psi.
2010 F350 Dulley King Ranch
2013 Cardinal 3800FL
2006 Yamaha Tour Deluxe with a Hannigan Trike Conversion
2009 Honda TRX 420FA Red (Hers)
2009 Honda TRX 420FA White (Mine)
EricRobinson8
Fountain Valley CA.
I have had good luck with the Maxxis 8008 tires.
2006 F-250 CC PSD 4X4
2007 Raptor 299MP
Pullrite Superglide
Sprinks542
Western Pa.
Thanks for the info gw48, I'll take the advice and look into it. Anybody have any other recommendations?
mydazeoff
Annapolis MD
I put on a set of Cooper LT truck tires, load rated E, 80 PSI. They roll fine and I'm happy with them. Shop around you might find a deal in the size you need.
2006 GMC Sierra 2500HD Duramax LLY, CC, LB
2005 Jayco Eagle 323RKS
Reese 15000 lb. 4 way hitch
Annapolis, Maryland
cbmiller
Morgan, Utah
I'm going to be replacing my Carlisle tires with the Goodyear G614. Right now there isn't much of a option if you want to stay away from china made tires. All the ST rated trailer tires are made in china. That leaves the LT rated tires and to get the needed capacity you need go with a "G" rated tire.
lincster
Mesa Az
Michelin XPS Rib. Best E rated LT tire out there.
I would also run the BFG commercials. Also a very good tire.
Any LT tire is going to be better than a ST tire.
2012 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
gbsb
Mt Pleasant Texas
We have a Fuzion toyhauler wich is 40' triaxle we repaced our Carlises with Hankook 7.50 R 16. They are a 14 ply tire. We live in North East Texas and there is a lot of cattle trailers amd hay trailers out this way. These tires were recomended to me by a friend that has been in tire busniess for years and sales them to ranchers here that haul heavy. We put over 15,000 miles on them last year with no problem. Very pleased with them From Texas to Alaska and back to Texas. George
joebedford
Jasper, Ontario
lincster wrote: Any LT tire is going to be better than a ST tire. Troll!
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
lincster
Mesa Az
joebedford wrote: lincster wrote: Any LT tire is going to be better than a ST tire. Troll!
HAHA. Thats funny. I am the farthest thing from a Troll. I just speak facts.
