dtzackus
Cumbola, PA
I have an 07 Chevy Avalanche with the 5.3 liter. I want to replace my shocks (both front and back). I would like to go with shocks that are made for towing, any recommendations??? Thanks in advance.
Dan, Tammy, Cory, Leah and Adam
2011 Chevy Silverado 2500HD 6.0
2012 Conquest 297DBS
Equal-i-zer Hitch
GM Integrated Trailer Brake Controller
ScottG
Bothell Wa.
I can tell you that Bilstien was the only brand I've used that actually controls porpoising. The Rancho's I tried did nothing for it.
Scott, Grace and Wesly
H0NDA eu2000i
dtzackus
Cumbola, PA
I noticed with our old camper, the rear end would squat down, now with the newer rig (and of course heavier) I brought it home with just the bull nose hitch (no WD bars), but the rear end really squatted down, not sure if I should go with a better shocks or maybe even sort of air bag system.
Ron3rd
Upland, CA USA
First you need to get your WD bars installed and set up correctly and see where the rear end sits. Shocks are not used to raise a vehicle, but Air Bags are and could be an option for you. Without the WD set up correctly, you don't know where things stand (or sit).
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
SoCalDesertRider
SanDiego, CA, USA
Bilstein, KYB and Rancho all make good shocks. I prefer Bilstein. I have had all 3 brands on various vehicles.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
94fxds
Rancho Cucamonga ,Ca
I have a Ford F-250 and put 4 Bilstein shocks on my truck after reading all the positive things about Bilstein shocks on this site. The Bilstein shocks destroyed the ride on my truck, the ride was choppy and rough. I tried to return them and they wouldn't take them back. I sold them on craigslist for half of what I paid for them. I put Rancho 9000 shocks on which have adjustable settings and I love the Rancho shocks.
bedrocker
lompoc ca
KYB's here
goducks10
Keizer OR
Shocks do nothing for ride height. They just control up and down movement. If your rear is sagging, readjust your WD setup. Your TT is a load for that Avy. You'll be at around 7800lbs loaded, so your TW will be close to 1000lbs. Not sure what the tow rating for the reciever is but you could be close to going over. I would put 7 washers in the EQ and make sure you have 12-1400lb bars. As far as shocks go I have run Bilstiens 5100's on our older 08 F150. They were great. On our 10 F150 I went with Ranch 9000's adjustables. Very nice also. If I had to do it again I would go with the Bilstien 5100's again. Cheaper $$. The adjustablitly factor of the Ranchos is nice but the ride of the 5100's was good enough.
kpratte
Southern NH
There aren't shocks for towing or not for towing.. Shocks will fix one problem or another. The stock shocks on my TRD Tundra were a little soft and I had some bouncies going over expansion joints on bridges, etc. I explored what some of the other Tundra folks did and their experiences with them and went with some Bilstein Heavy Duty ones that people liked. They are stiffer for rebound and for initial damping.
The gotcha with all of this is unless you can find an adjustable one, you may get ones that you may or may not like. The adjustables ones are nice as you can leave them soft for driving around town and then when towing you can adjust them harder to get rid of some of the bounciness from the extra weight.
- Ken
2010 Toyota Tundra 5.7 CrewMax Limited, TRD Swaybar, Timbrens, Bilstein HD shocks
2012 Keystone Sprinter 272BHS
Reese DC Sway, Fastway Flip, Tekonsha P3
Yamaha 2400iSHC Generator
