tporter
I have four house batteries along with two other batteries that start the motorhome. Total of six batteries. The house batteries are older, i'm not sure how old. I have owned the motorhome for three years and haven't replaced them. If I try to start the generator without the motorhome running the generator won't start. If I start the motorhome first then the generator will start. When I shut the motorhome off the generator will die.
I have separate battery switches for the motorhome batteries and the house batteries. Could my generator batteries be shot which is making me think I have an electrical problem? Does the generator charge the four house batteries or does the alternator from the motorhome charge all batteries?
2003 Fleetwood Discovery. Cat motor, Onan generator
Ka Ron
Kelowna
I am thinking (a dangerous thing) that the generator uses the house batteries to start and not the chassis battery??
If the coach batteries do not have enough power when you start the engine the power from the alternator is starting the generator, but when you shut the engine off there is no power from the house batteries and that would be why the generator dies.
Have you tested the house batteries to see if they are good??
Join Us For A Trip Down The RV Highway
garym114
Bluff Dale, Texas
Do the 12v lights work without the gen or shore power?
All the iterations with the generator points to discharged house batteries.
The gen provides 110v power for the converter to charge the house batteries and the alternator should charge all batteries.
Dale.Traveling
Newport News, VA
tporter wrote: When I shut the motorhome off the generator will die.
I'm thinking electrical just by that statment. You need DC to run the fuel pump. Does anything that is DC powered work when the generator, engine, and shore power are off such as lights or the water pump? Almost sounds like the entire DC network for the coach has been turned off.
2006 Hurricane 31D aka 'Moby' the Whale
FCC(SW) US Navy Retired 1980-2003
Stella my Navigator
Bogart the All American RV Dog
and
Cocoui waiting for me at the Rainbow Bridge
tporter
1 house battery tested bad the other three were weak.
The 12V lights work and seem bright although I would just turn them on to see in the coach then shut them off.
Since I don't know the age of the house batteries (they are at least 3 years old) I will start by replacing them. I had another problem with my batteries not charging from sure power, my digital readout would just went blank when plugged into shore power after 10 minutes or so. Maybe my batteries are too weak or have shorted out which is causing my problem?
RayChez
Barstow, Ca. USA
Sounds to me like you might have a bad transfer switch in your inverter/charger and it is not charging your house batteries.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
rvrepairnut
bc
tporter wrote: 1 house battery tested bad the other three were weak.
I beleive if you replace the 4 coach batterys and make sure all your
cable connections both+ and - are good it will solve your delema
based on what u said is happening in your first post
chewbear
Mobile in the USofA;currently Ozark, Alabama
In my 2002 Alternator charges both house and coach. Generator charges both house and coach. Shore power charges both house and coach. When My Alternator went bad, ran generator to charge coach set and it kept motor running till I limped to help.
2002 Fleetwood Discovery
330 cat. '09 Escape toad.
Kathy & Joe wish you well.
My mind works like lightning,
one brilliant flash and it's
gone. (Maxine)
hershey
Albuquerque,(fulltime) NM, USA
I'm bettin' that the house batteries start the generator. I'm bettin' that at least one of the house batteries (probably more) is bad and not giving you full power that the generator needs to start.
Can you test the output of the house batteries without anything charging them? Test them at least an hour after you have had not charging power either engine or shore power to them. They should show about 12.6 or 12.7 volts but anything over 12.4 should start the generator.
Remove the cables from the negative side of the bank of batteries and check the voltage of each battery. I'm bettin' that you'll find a dead battery.
Sounds like I'm doing a lot of bettin', but I'm bettin' I'm on the right track.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
Dale.Traveling
Newport News, VA
RayChez wrote: Sounds to me like you might have a bad transfer switch in your inverter/charger and it is not charging your house batteries.
This is what I'm thinking also. Most, if not all, have a built in circuit break and also a fuse(s). Very esay to check.
