DKean
Mays Landing NJ.
I did the google search and found nothing. Anyone have a link for one?
2006 F350 CC LB 6.0 diesel dually. 2006 Cedar Creek fifth wheel. Six 6 volt golf cart batteries,3000 watt inverter. Mountain Master generator in truck bed remote start. Automatic satellite dish.Air suspension on truck and trailer.Level up with 6 jacks RC
downtheroad
Pacific Northwest
Check HERE
Or any dealer's parts dept.
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
greende
Syracuse,NY
So, I take it that yours is "toast". If I needed a new rear bumper, I would go to a place that sells steel and pick out some square tubing and have a welding shop weld it the right way. Most of the rear bumpers are so flimsy that they aren't much worth it.
2011 Chevy 3500 HD LTZ Duramax/Allison Crew Cab Long Box DRW
B&W Turnover Ball with Companion
2012 Keystone Cougar 293 SAB 5er
rattleNsmoke
Western Conn.
I bet you could have a bumper fabbed by a welding shop then powdercoated for the same cost as a pre-fabbed unit and made MUCH stronger. It's only 4" tube stock.
Mike
2010 Cedar Creek 34SATS (The Beast) & 20k Curt Q20 roller slider hitch
2006 Ford F350 SRW,SC Powerstroke diesel Lariat
2003 Harley Heritage Softail (Hogzilla)
and a wifey with tons of patience....
powderman426
ohio
rattleNsmoke wrote: I bet you could have a bumper fabbed by a welding shop then powdercoated for the same cost as a pre-fabbed unit and made MUCH stronger. It's only 4" tube stock.
Mike
And if you go that route, make sure they use either polyester or urethane. The epoxy is tough, but it will chalk in the sunlight and you will always be cleaning it.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
sloopdog 1
Stanley,N. C.
I bent my 5er bumper by backing into a small tree.Got some 4x4 steel tubing and made my own replacement.Painted it black with a couple cans of spray paint from lowes.No rust yet, been two years.You can't put the sewer hose in the replacement bumper, because the wall thickness is greater.(1/8 inch).
2001 F250 7.3 supercab,Pullrite Superglide,2008 Copper Canyon FW339tsl
Bipeflier
Centralia, MO
Or just look along the shoulder on any interstate. They are occasionally laying there, usually with a spare tire or bicycles and rack still attached.
2010 Cruiser CF30SK Patriot
2011 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
ScottG
Bothell Wa.
I did just like Sloopdog but went overboard with 3/8" thick. I meant to tell them 3/16 and didn't realize my mistake unitl after I got home with it and wondered why it was so danged heavy.
Had a friend weld it on and I suspect I could dangle the entire TT form it. Painted it with good quality spray paint and after 3 years it still looks great.
Scott, Grace and Wesly
H0NDA eu2000i
rattleNsmoke
Western Conn.
Damn, a 3/8" steel wall Rock Crawler bumper is what I had made up for my kids Jeep Cherokee. It musta been one heavy mutha.
Mike
Bachus
Stratford, Ontario, Canada
Had my welded up by a local fab shop. 400 bucks + the cost of a spray bomb once a year. Way better than factory.
Dean and Tracy Bachellier
Isobel,Evelyn, and Stuart
2012 KZ Durango D355BHS quad bunk with 5 slides
HiJacker 16K double pivot slider
2011 RAM 3500 SRW Crew Cab 4X4 CTD
"It's five o'clock somewhere...."
