Bob1180
Lancaster, Ohio
I have a 5th wheel I tow using a Prodigy3 brake controler. It does a decent job, when I keep the brakes adjusted, but not great. Sometimes I feel as if the brakes are not getting sufficent Amps on hard braking. Is there another controler anyone has used that may work better the the Prodigy. My mechinac is not impressed with the prodigy.
jmtandem
western nevada
Bob,I have the Prodigy and have found that it requires adjustments for conditions. It is not a set it once and forget it controller. Having understood that, it works fine for my 31 foot TT application.
You might also make absolutely sure the brakes on your fifth are adjusted correctly and getting the amps needed at each wheel.
edited 04/05/12 08:43am by jmtandem *
'05 Dodge Cummins 4x4 dually 3500 white quadcab auto long bed.
'09 299bhs Tango.
tvman44
Southwest Louisiana
Most trailers have very poor wiring from the factory, if unhappy with the braking the first thing I would do is rewire the trailer brakes.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
halibutman214
Oregon
tvman44 wrote: Most trailers have very poor wiring from the factory, if unhappy with the braking the first thing I would do is rewire the trailer brakes. With all due respect... you have to be kidding! I "don't think", I'm getting the correct amperage and I'm going to rewire the brakes!
As was already said you can't just set the prodigy and forget it. Have you adjusted it to the max? Will the manual override slide the tires? You have a bunch of trouble shooting to do before you even think about rewiring and if your "mechanic" didn't tell you all of this already I would be looking for a new one. As far as Prodigy it's one of the best controllers on the market.
edited 04/05/12 06:29pm by halibutman214 *
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
craigwieck
michigan
I have the same problem with my p3. I almost got into an accident on the way back from Florida in December. I checked them before I left for the day. When I got into Ohio I had some one pull out in front of me on the free way doing 25 mph. When I hit the brakes I had no help from the trailer. I tried the manual lever and there was nothing. I adjusted them up all the way to get home. Half hour from home I hit the brakes and the traile locked the brakes up. I just pulled the wheels off my trailer to pack the bearing and look at the brakes. The shoes, and magnets all looked good I adjusted them and when I took my trailer back to storage they still did I not work. The only other thing I can think of is the 7pin on the tv might have a loose connection. I was also taking to my parts guy at general trailer and he said to call the company and tell them what was going on. Said it has a life time warranty. Im going to look into it this week so if I find out anything I'll let you know. Not that it maters much but i am a ASE certified mechanic that did electrical at a ford dealer for 12 years so I know a thing or two about this stuff. That being said I will call the manufacture to find out if there's a pin point test I can do before I condem the controller. Wll give an update as soon as I do.
2010 larado 303tg
2005 excursion v10
Jayco25E
PA
Most folks on here would give up their fist born child before giving up their P3 or P2 brake controller. They are that good. Like others have mentioned I think there is something else wrong if your P3 is not working the way it should.
2008 Chevy Avalanche
2005 Jayco 25E HTT
2 retired Greyhounds
bigjettech
Bartlett,Il
The prodigy I had worked great on the 24' TT I owned. but ever since I got my 32' fifth wheel I've been less than impressed with it. It worked fine slowing down at higher speeds but at lower speeds such as the final 20-30' coming to a complete stop at a light or stop sign the brakes woud jerk excessivly. I've been all through the brakes and was confident it wasn't a brake issue. I just bought a MaxBrake controller and installed it. It's like night and day compared to the prodigy. The MaxBrake is smooth even braking all the way to a complete stop.
2006 Silverado 2500hd duramax 4x4 - with a few mods
2006 Cherokee lite 285b+ 5th wheel
craigwieck
michigan
I was looking at that controller. I am going to see what tecknosa says and if I'm not happy I'm going with the max controller.
wittmeba
Virginia
As far as aftermarket controllers, about the only other brake controllers that I would think to be better is the MaxBrake or DirectLink.
DirectLink is new and there still seems questions on its operating principle.
MaxBrake works on the Master Brake Cylinder brake fluid pressure and a pressure transducer to produce 0-12VDC output. It has a very good reputation.
By your description it sounds like you support my concern with marginal brakes/axles on larger trailers. The test has been whether you can lock the wheels or not.
http://gotnarcosis.com/brucewittmeier/technical/BrakeControllerSelection.html
I was born in Great Falls, Mt. My parents moved when I was 5. I found them when I was 10 - they were in California.
Firefox® 21.0
Log home images - Updated 05/19/2013
BenK
SF BayArea
Lots of things that can be done to super tune the system
My GMT400 K3500/7.4L/4.1 Suburban has it's P3 adjusted to initiate the trailer
brake controller to send power to the trailer brakes before the TV's MC ever
see's braking hydraulic PSI
I can stop the whole setup via the TV brake pedal without EVER setting the TV's
brakes. Do this in stop-n-go traffic. This also keeps the trailer brakes heated
and ready for an E stop. All this without ever touching the manual lever on my P3
Then the very, very poor quality (workmanship, materials, sizing, etc) of 'most'
trailer braking system harness. Ditto the trailer brakes, they almost always need
some level of super tuning
Finally, the shoes are never the best friction materials. Gave up on that after
my local brake shop that reshod (sp?) new friction material to my choices retired. Just
look for the best and most HD shoes you can find. The choices here locally are
not good
-Ben Picture of my rig
