RV.Net Open Roads Forum: Toy Haulers: Yamaha EF2400iSHC not powering Toy Hauler
Search only in Toy Haulers
 > Yamaha EF2400iSHC not powering Toy Hauler
ecav
Rescue, CA
Posted: 04/05/12 09:00pm Link  |  Print  |  Notify Moderator
Having techinical issues here ... I recently sold a '98 Jamboree Class C motorhome and picked up a 2006 Eclipse Attitude Toy Hauler. Both RV's have onboard generators which work perfectly. I purchased a Yamaha EF2400iSHC which I prefer to use - I can put it away from our camp and it is much quieter. This setup worked perfectly with the Jamboree motorhome, but it is not powering the Toy Hauler ...
When I plug the Toy Hauler in to my house, everything works perfectly - no problems there.
The Yamaha generator works perfectly on it's own. I can plug things in to it directly and they work, and I have used an electical tester and it is reading 110.
It stands to reason that I should be able to plug the Toy Hauler in to the generator and I should be in business, but I have ZERO power in the Toy Hauler when plugged in to the generator - no lights, no anything.
I have checked fuses and circuit breakers, no problems there. If I unplug the Toy Hauler from the generator and plug it right in to my house, the power comes on.
Any ideas what could be wrong here??
Thanks in advance for any help you may have for me!
ScottG
Bothell Wa.
Posted: 04/05/12 09:06pm Link  |  Print  |  Notify Moderator
Welcome, Just an FYI per the rules: "You are not allowed to post the same message in multiple forums without permission from one of the Open Roads Forum moderators."
Scott, Grace and Wesly
H0NDA eu2000i
ecav
Rescue, CA
Posted: 04/05/12 09:21pm Link  |  Print  |  Notify Moderator
Sorry! Wasn't sure which forum this belonged ... my apologies.
xaugievike
Chicagoland
Posted: 04/05/12 09:28pm Link  |  Print  |  Notify Moderator
is there some sort of on board surge protector or something that has been installed that may be reading the generator as an open-ground?
Or is the circuit breaker on the generator itself tripped? (motor still runs - no power coming out). Do other devices like a fan or something run off the generator?
2006 Chevy Silverado 2500hd D/A LBZ
Pulling Keystone Cougar 325SRX
dedmiston
Valencia
Posted: 04/05/12 09:32pm Link  |  Print  |  Notify Moderator
Hey Ecav,
Welcome to the forum. Don't worry about the double post. Now you know the rule. The Forum cops aren't going to kick in your door and take away your keyboard. Take another look at the Forum Rules when you have a minute and familiarize yourself with the dos and don'ts. It's a short list of stuff that you can't do here.
Enjoy yourself here. It's a good group.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
  • 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
pianotuna
Regina, SK, Canada
Posted: 04/05/12 09:52pm Link  |  Print  |  Notify Moderator
Hi,
Does the new RV have GFI breakers? If so that may be the problem.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
ecav
Rescue, CA
Posted: 04/05/12 10:58pm Link  |  Print  |  Notify Moderator
dedmiston wrote:
Hey Ecav,
Got it - multiple posts is the 2nd rule listed in the guidelines - geez! Sorry again!
ecav
Rescue, CA
Posted: 04/05/12 11:08pm Link  |  Print  |  Notify Moderator
The fuse panel does not show any kind of surge protector - just fuses and circuit breakers. The generator has an auto reset ... all indications are that it is working just fine (it only has 20 or so hours on it). It seems that the generator is not producing the same amount of power as my house ... is this possibly the problem? Is there some kind of converter necessary that I need to run in between the generator and the RV? I know that my generator says "converter" on it, and there is a converter below the fuse box on the RV ...
Thanks for your help!!
ecav
Rescue, CA
Posted: 04/05/12 11:53pm Link  |  Print  |  Notify Moderator
pianotuna wrote:
Hi,
There is one GFI breaker in the bathroom, and it has not popped out - it seems fine.
pianotuna
Regina, SK, Canada
Posted: 04/06/12 05:09am Link  |  Print  |  Notify Moderator
Hi,
Does the Toy Hauler have an energy management system?
Is there a transfer switch?
I'd check the output of the Yamaha with a polarity tester, and compare that to shore power and to the built in genny.
* This post was edited 04/06/12 05:16am by pianotuna *
