RV.Net Open Roads Forum: Ram 3500 owners - asking for a friend
Search only in Tow Vehicles
 > Ram 3500 owners - asking for a friend
summithmk
butt#$%$ egypt, NV
Posted: 04/06/12 10:17am Link  |  Print  |  Notify Moderator
My 2010 3500 Ram does sag more than my 2007.5 GM did but not by much.
FishOnOne
Katy
Posted: 04/06/12 10:36am Link  |  Print  |  Notify Moderator
Interesting....
I think it's fair to say the '11 F250 with it's new springs squat more than the older F250's.
GM's new models seam to be consistant with their older models.
45Ricochet
North Idaho
Posted: 04/06/12 11:06am Link  |  Print  |  Notify Moderator
JIMNLIN wrote:
Number of leaf springs doesn't mean anything when compared to another brand truck. The springs width/thickness/spring length/steel psi rating can be different between the manufacturers.
Jim is right the width and thickness can be a big difference. Donn also brought up a good point with the unloaded rear being higher than the front. When under load and within rating it squats to level, hopefully.
JFYI ours squats 3-4" with a 3200 lb pin weight and not much more with about 5000 lbs of gravel in the box. It would be interesting to know the pin weight of the RV.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
eric james
Sioux Falls, SD
Posted: 04/06/12 01:04pm Link  |  Print  |  Notify Moderator
My inlaws have a 10 Ram 3500 SRW Quad cab
Truck capacities:
GVWR: 10100
GAWR F: 5500
GAWR R: 6500
GCVWR: 21000
Towing: 13600
Actual loaded weights:
Truck: 10820
Front axle: 4860
Rear Axle: 5960
Trailer axles: 10100
Combined: 20920
They're only 500 lbs under the rear axle capacity and not running bags. I'd say it's a touch down from level in the rear. It has a pretty good tail up unloaded.
It's amazing how a 12000 lb fifth wheel almost taps out their 3500. It has 2000 lbs dry pin weight - ouch!
* This post was edited 04/09/12 08:15am by eric james *
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
larry barnhart
wenatchee. wa usa
Posted: 04/06/12 01:11pm Link  |  Print  |  Notify Moderator
I see many fords and rams towing with the rear of the truck lower from the load. I think it is the distance between the overload spring and the springs.
air bags will fit the problem if it is a problem.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Navy_LDO
Wash, DC
Posted: 04/06/12 01:49pm Link  |  Print  |  Notify Moderator
Thats the reason I went from my 2003 SRW to my current dually. Air bags fixed the sag on the SRW but it didnt feel good going down the road with the Carriage. Upgraded trailer before truck!! Lesson learned.
A shame, since my 2003 5.9L/3.73 got really good mileage in the 19-20 mpg range empty.
2007 Dodge 3500 6.7L, 68rfe, exhaust brake, 4x4, Pull Rite Super Fifth, Prodigy
2005 Carriage CW378, Onan 5.5 LP, Astro Foil, Dual Pane Windows, Mor-Ryde IS and Pin Box. (Former Full-time House)
2006 Eagle Cap 950, 85 watts of solar
summithmk
butt#$%$ egypt, NV
Posted: 04/07/12 02:22pm Link  |  Print  |  Notify Moderator
catfishmontana wrote:
My 2010 Ram 3500 Dually was really soft in the rear. It rode nice, but when I traded it in on my current F350 SRW, I noticed right away that our TT made the F350 squat way less then my Ram did. Way less.....
IB516 would disagree.
Greentreena
British Columbia
Posted: 04/06/12 07:36pm Link  |  Print  |  Notify Moderator
Are the tires running the proper presure?
My 08 SRW 3500 does squat a little bit compared the previous Ram SRW 2500 I had pulling the same 5th wheel.
It is a bit noticable at night with the low beams higher than some oncomming drivers would like. I usually avoid towing at night anyway so it isn't too bit a deal.
2008 Dodge Ram 3500 6.7 Mega Cab 4x4 SRW
Hijacker Auto Slide/ P3
2006 Triple E Topaz 310RBXL
Wife, 2 kids and Murphy the dog
Pictures
catfishmontana
montana
Posted: 04/06/12 06:01pm Link  |  Print  |  Notify Moderator
Mine ~ 2011 Ford F350 6.7 SRW, CC/LB, Lariat, Navigation, FX4, 20's, Black with Black Guts.
Hers ~ 2012 Ford F150 Raptor, Blue Flame, Crew Cab, 6.2L
GONE!!! 2010 Chevy Tahoe LTZ 5.3 ~ Most worthless POS ever!
2007 Keystone Montana Mountaineer 30FKD TT
