I wanted to see if anyone has replaced their refrigerator in a pop-up. I have a 2003 Fleetwood Laramie and the condensor is leaking. I believe I need to replace it. It can be operated via electric or gas. Has anyone replaced one? Is it difficult? Where do I buy a replacement.
Best thing to do is just jot down your RV trailer fridge model number and search for it on GOOGLE... My 2008 STARCRAFT POPUP fridge is Dometic RM2191/2193 model
You should have a folder somewhere with all of the installed appliances datasheets in it. Most of them will have installation info in the datasheets.
looks like the same one I have...
2008 Fleetwood
2003 Fleetwood
edited 04/06/12 10:24am by RoyB *
My Posts are IMHO based on my experiences - PM me Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
I just had to replace the 12v/120v fridge in my boat. The price for these small 2cuft fridges new are outrageous, and I believe the propane/120v versions are just as expensive. If you can get away with just having a 120v version, you might be able to find one that will fit your trailer at Lowes or a similar store for under $200.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
