vacuumbed
Salt Lake City, Utah
On my new to me 96 Monaco Executive I am going to remove the In-Motion satellite dish.
What is the best or most professional way to patch the holes in the roof after removal?
Thanks in advance.
rvrepairnut
bc
vacuumbed wrote: On my new to me 96 Monaco Executive I am going to remove the In-Motion satellite dish.
Thanks in advance.
take a piece of thin sheet metal and seako flex it over the area where the dish mount holes were.fill holes with seako flex first
Oasisbob
Portland Oregon 97266
So you are talking bolt holes? Prep, Bondo, sand, prime & paint
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
vacuumbed
Yes, the bolt holes.
I have a professional grade body filler called Z-Grip. It's not for fiberglass per say, but for automotive metal.
It seems like this would be a good solution. Is it still okay to use this on a fiberglass roof?
rgatijnet1
I would use fiberglass resin and a small amount of cloth. The trouble with some automotive fillers is that they may not expand and contract the same as the fiberglass, which may cause a leak, if they separate. Small fiberglass repair kits are available at most auto stores.
SCVJeff
Santa Clarita, CA.
These aren’t gaping holes are they? Why not just clean and put an Eternabond patch on them? Done right it will absolutely never come off and last forever.
Jeff - WA6EQU
Roadpilot
NH Seacoast
I've used Bondo on fiberglass and it has a different rate of expansion and contraction i.e. it cracks at the edge. Try a fiberglass based Bondo or a Fiberglass repair kit.
2006 Millennium Prevost
2013 Chevy Avalanche LTZ Black Diamond
2009 HD Electra Glide CVO Screaming Eagle - mine
2009 Yamaha VStar950 - DW
Cruiser Caddie motorcycle lift
The Beave
Georgetown TX USA
Nothing is faster or lasts longer than Eternabond tape! Here: http://www.eternabond.com/?Click=2059&gclid=CJ7xmtugoa8CFSFgTAoddHy-XQ
The Beave
30' 1997 Beaver Monterey
(The shortest DP we could find)
2005 Honda CR-V
Remco surge brake
sam7
Garden Grove, CA
I did the same thing that you are doing. I used Eternabond to cover the holes. Just clean the area and apply the tape. It's quick and easy and will last longer than you will own that motorhome. It is not noticeable, cleans easily and won't leak.
2001 Foretravel 36' U320
2007 Grand Cherokee
gbopp
The Keystone State
Eternabond
