RV.Net Open Roads Forum: LT tires, BFG Commercial TA or Michelin XPS Rib?
 > LT tires, BFG Commercial TA or Michelin XPS Rib?
Page of 5
steelpony5555
Copperas Cove Texas
Posted: 05/04/12 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Had BFG's on the last 5er for 4 years no problems and also on both trucks. Just bought a new 5er with brand new Marathons and went in and got new BFG's on it too. Check Discount Tire, I got 4 BFG's installed with a warranty for $900. I think you pay a lot for the name with Michelins just like any product that makes a name for themselves. Still an excellent choice, but there are tires out there now that will do just as well, BFG's being one. We travel a lot in Texas at 70 mph in 100+ degrees over the past 4-5 years with no problems.
06 Montana 3000RK
07 Dodge 3500 Dually Sport 6.7 Diesel
07 Pearl White Ultra Classic (My new Baby)
10 Chrysler 300 Touring
Texas Boomers---Stop by for a Margie some time!
larry barnhart
wenatchee. wa usa
Posted: 05/04/12 09:17am Link  |  Quote  |  Print  |  Notify Moderator
We had BFG TA commericials on our truck and they were very good. Steering was great towing and solo driving. I was going to buy this tire again but decided to try the michelin MS2. To compare the tires I looked at the spec's. I was surprised at the different weights of tires. I looked at the duro that comes on the cameo my friend bought in 2011. That is a very lite tire. I was very happy with the BFG tires on the truck and I hope what we bought will be as good. My guess for a fifth is to not twist the tires backing into an rv site.
Just what I feel is common sense tire talk.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
steelpony5555
Copperas Cove Texas
Posted: 05/04/12 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
With all the stories of belts separating, I have always thought that was the biggest problem with trailer tires is when folks jack their trailer around in a tight turn. I spent a lot of time towing with a short bed and I never had to use the slider hitch. I treat my new truck the same way. I avoid places where I have to get almost 90 degrees. Just watch a buddies trailer tires sometime if you are around and they jack their trailer 90+ degrees.
cabanaman
florida
Posted: 05/04/12 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Just have to add that the uniroyal laredo hdh is also in the michelin family.It is a clone of the bfg commercial ta.Mine have held up fine over 3 years now fulltiming.
Retired Navy
2007 Dodge Ram 2500 quad cab 6.7 cummins,6 speed auto,exhaust brake.
2007 Open Road 378SA4S-5,equa-flex and morryde X factor,wet bolt kit,michelin ltx M/S 2 tires
http://www.gofundme.com/Carebear (my daughter)
JIMNLIN
out here
Posted: 05/05/12 06:33am Link  |  Quote  |  Print  |  Notify Moderator
The HD-H Uniroyal was OEM for years on the HH II trailers with 6k axles. Great record.
New regs in '08 required 7k axles so HH II had go with the problematic maypops or owners could choose the 17.5" LT option.
'97 Park Avanue 28' 5er 11200 gvwr two slides
scotjima
DFW
Posted: 05/05/12 07:01am Link  |  Quote  |  Print  |  Notify Moderator
I purchased four BFG Commericial TA in LT2257516 LRE for my 2008 Cougar 314BHS trailer about three years ago. These replaced the original 15" Duro ST tires and steel wheels. I purchased the tires, wheels, and road hazard at Discount Tire.
I have put about 4000 miles on these tires with most of the miles being a single trip. The trailer does sit for 6 - 12 months without moving. The tires are covered.
Today, I replaced the four mounted tires with the same size Michelin X-RIBS. The four mounted BFG had all cracked in multiple places around the tread/sidewall seam, and in the middle of the sidewall. I believe this was likely caused by the trailer sitting still for such long periods.
SkiSmuggs
Northern Vermont
Posted: 05/05/12 08:27am Link  |  Quote  |  Print  |  Notify Moderator
I've read that tires require occasional movement to distribute protective oils. Stored RVs should be moved a least a little occasionally.
2011 F150 Super Crew EcoBoost, Short bed, Max Tow, Truxedo Lo Pro QT, SuperSprings, Bilstein HD shocks, Reese 16K hitch.
2012 Cougar High Country HE 299RKS 5th wheel, Reese Sidewinder pin box
dlkc
Crosby,Tx
Posted: 05/05/12 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Does discount make you bring the wheels/tires in w/out a trailer in order to mount the tires on?
I just ask because when I had walmart put tires on my last trailer they said by law they could only mount trailer rated tires on a trailer (I drove it up there between storage locations.)
2011 Ford F-250 4x4 Crew 6.7l w. Bags & B&W Companion Hitch
2012 Satrcraft 278 BHS
2009 Polaris Ranger
scotjima
DFW
Posted: 05/05/12 09:12am Link  |  Quote  |  Print  |  Notify Moderator
No. I backed the trailer up to their side door and they brought four floor jacks out. Left the trailer hooked up to the truck. They told me it was easier to warranty LT tires vs ST tires for cracking. Since they are "truck" tires, they are expected to last longer than the ST tires.
steelpony5555
Copperas Cove Texas
Posted: 05/05/12 09:14am Link  |  Quote  |  Print  |  Notify Moderator
No, Discount will do it, you just have to find one with a decent size lot to get your rig in and turned around. Some have small lots. Walmart is a pain in the butt when it come to buying tires. My daughter and I had a custome VW Beetle Bug that had aftermarket wheels and tires on it. When parked at school someone slashed all 4 tires. I took them off and ran them into Wallyland. They asked what it was off and said nope they would not put the tires I wanted on it because they were not factory???? Had to argue with them and finally they said they would do it but you don't get no roadside warranty lol lol Ooooooooo that worried me lol lol.... I don't know where Walmart gets this law from, I think they are the only ones like that. Probably afraid of getting sued.
Page of 5
