How would I go about installing those wire things that hold plastic wrap, foil, etc. I want to install a few inside my cabinet doors and bathroon door. I don't think I would want to drill holes.
Thanks
You might try 3M command brand hanging strips- I just tried them for some household items. they stick to the walls but when you go to remove them they do not damage the walls- NO I do not work for 3M- but I do work for Home Depot and the product does seem to do as advertised.
Tazymae; First measure each cabinet door for width. The ideal width of your basket will want to be approx 1"to 11/4" less than door width. Finding the right sizes is going to be the hard part. When you install them with wood screws you must drill a pilot hole the size of the screw shank. If you don't you may split the style. Hope this helps,Happy Easter.
