RV.Net Open Roads Forum: Class A Motorhomes: LP Gas
eadeal55
Suffolk VA
Posted: 04/09/12 10:04am Link  |  Print  |  Notify Moderator
If you have your coach plugged in at home to keep the fridge cold in between trips, then I would keep the propane on just incase of power failure. That way, you don't lose the stuff in your fridge/freezer.
If the coach is being stored with all the electric/battery power off and fridge/freezer empty, then I would turn off the propane too.
Andy & Lee, plus Ruby & Bella, the Cocker Spaniel girls
'05 Fleetwood Bounder 33R, F53 w/6.8L V10...towing a
'07 Chevy HHR LT2 w/2.4L EcoTec,
Blue Ox Aventa LX, Brake Buddy Classic
FMCA #F359977 - Colonial Virginians
FCRV #733452 - Tidewater Wheels
ArchHoagland
Clovis, CA, USA
Posted: 04/09/12 10:16am Link  |  Print  |  Notify Moderator
I've never shut mine off in seven years.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
Tinstar
McKinney, TX
Posted: 04/09/12 11:29am Link  |  Print  |  Notify Moderator
It's hard to use gas appliances when it's turned off but you can if you are not using anything that runs on propane.
Never pass up a chance to go somewhere
workhardplayharder
Treasure Coast Florida
Posted: 04/09/12 11:42am Link  |  Print  |  Notify Moderator
I keep mine on to keep the system pressurized to prevent moisture from getting into the lines. If there are no leaks it doesn't hurt to leave it on.
