RV.Net Open Roads Forum: Tow Vehicles: Looking at 2009 Dodge 3500. Opinions?
Search only in Tow Vehicles
 > Looking at 2009 Dodge 3500. Opinions?
eric james
Sioux Falls, SD
Posted: 04/10/12 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I rarely see people complaining about their CumminsTD compared to the 6.0TD Ford.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
donn0128
Pronounced Ore-gun
Posted: 04/10/12 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
rjstractor wrote:
If you can see warranty repair records and they look good I would say go for it. A buddy of mine has an '08 and it's been in the shop more times than he can count for EGR problems.
Since it is likely how he is driving it I would suggest he do the deletes and go down the road happy once more.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
FishOnOne
Katy
Posted: 04/10/12 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Brother in law owned a '09 RAM with the 6.7 and after several trips to the shop for CEL which was caused by soot build up in the turbo he was forced to unload it after ~9 months and purchased a used 5.9.
I think the 6.7 is fine if you work it hard like pulling heavy loads constantly, but use it as a daily driver with alot of idling and the emissions equipment can be a nightmare on these engines.
His previous truck was a 04 6.0 power stroke that had EGR valves clog, but nothing like his 6.7 cummins turbo issue.
ritterjd
Vandalia, Ohio
Posted: 04/12/12 10:36am Link  |  Quote  |  Print  |  Notify Moderator
Well, the wife gave me the go ahead to buy this truck if I wanted, so I took it for a test ride.
The truck had tons of power and acceleration, much more than my 6.0L PSD, but the ride was awful. It may have been tire related but you couldn't tell by looking. It ran smoothly at highway speeds but on local roads, I couldn't live with it, at least without a trailer behind.
As much as I hated to, I had to turn it down. I am by no means a Ford fanatic but had to tell the salesperson that it road like a farm truck and nothing like my Ford.
John Ritter
Vandalia, Ohio
2012 Canyon Trail Aztec 33FRET
2006 Ford F350 DRW King Ranch 6.0L Powerstroke Diesel
ib516
Up here!
Posted: 04/12/12 10:44am Link  |  Quote  |  Print  |  Notify Moderator
And people say making a half ton ride better is silly!
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/12/12 10:46am Link  |  Quote  |  Print  |  Notify Moderator
I would go back and check the tire pressure on the truck. Quite possibly, the rears were over inflated for having no weight in the bed. A dually doesn't need any more than 65 psi front or rear for an empty bed.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
larry barnhart
wenatchee. wa usa
Posted: 07/10/12 09:14am Link  |  Quote  |  Print  |  Notify Moderator
carolineanderson1972 wrote:
ritterjd wrote:
Your wife must be the breadwinner, it appears. No offense but that is a bit sad, especially in our world of RVing. Not very manly.
Guess we can all tell who wears the pants in your family! It must be emasculating to have to ask your wife's permission to make a purchase. If I tried that with my husband we would be divorced.
The word is "married" but what ever works, works
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
larry barnhart
wenatchee. wa usa
Posted: 07/10/12 09:15am Link  |  Quote  |  Print  |  Notify Moderator
I was thinking this could be the problem also or atleast worth checking.
chevman
johntank
Oxford, Ms 38655 USA
Posted: 07/10/12 10:02am Link  |  Quote  |  Print  |  Notify Moderator
If I remember right my door sticker on my 07.5 Dodge DRW has 65psi front loaded/unloaded and the rears are 45psi unloaded and 65psi loaded.
Tystevens
SLC, Utah
Posted: 07/10/12 10:46am Link  |  Quote  |  Print  |  Notify Moderator
Funny about the ride quality of the Dodge. Reminds me, a few months ago, I took a client for a site inspection in my '06 Chevy, about a 70 mile drive each way. He had driven GMs for years, apparently, and had just traded his in on a '11 RAM 2500 Megacab; he wanted the extra room. He must have commented a dozen times how much he was missing the ride of the GM.
2008 Hornet Hideout 27B
2010 Chevy Suburban 1500 LT, Z71 package, 5.3/6A/3.42
Prior TVs:
2006 Chevy Silverado 2500HD ccsb 4x4 LT, Duramax LBZ
2005 Chevy Suburban 1500 4x4 LT, 5.3 L, 4.10 gears, LT package
2002 Dodge Durango 4.7 4x4
