RV.Net Open Roads Forum: Class A Motorhomes: Wiper Link Ball Joint
 > Wiper Link Ball Joint
hypoxia
Arizona
Posted: 04/09/12 04:38pm Link  |  Print  |  Notify Moderator
My Revolution has metal tubes that connect to the windshield wiper motor and then to the wipers. There is a ball joint on the wiper motor and on the wiper assembly. The tube that connects them has a plastic piece that snaps over the ball on each end. One is broken/missing and I am trying to find a replacement. Denso only lists the entire link assembly.
* This post was edited 04/10/12 07:13am by hypoxia *
Jim
2003 Fleetwood Revolution 40C
Mustang7370
Washington State
Posted: 04/09/12 04:49pm Link  |  Print  |  Notify Moderator
Back in the day when things were made of metal, it was and still is easy to get wiper linkage repair kits to fix those loose or broken sockets. In today's plastic world, i would bet a dollar you are going to have to buy the whole link. At least that's how it is in the automotive repair world in which I live.
Chris and Kelli Withers
Ferndale, WA.
hypoxia
Arizona
Posted: 04/09/12 08:23pm Link  |  Print  |  Notify Moderator
It's a Fleetwood/Freightliner. I wanted to post a picture but ren into a techno problem & then had to go off on another project.
Jim & Betty
Brandon, South Dakota
Posted: 04/09/12 11:23pm Link  |  Print  |  Notify Moderator
I have a Freightliner Chassis and my wiper motor and related parts are from Cleavland Ignition. Look on the motor for Mfg.
http://clevelandignition.com/
jimR
jvander
Indianapolis
Posted: 04/09/12 08:55pm Link  |  Print  |  Notify Moderator
I would try Grainger or McMaster-Carr. Both carry industrial components such as ball joints. Can't look it up by Freightliner part # though.
1993 Coachmen Catalina 31'
Chevy P30, 454 TBI, Hedman Hedders w/ x-pipe and Jones Full Boar mufflers. Same mileage as stock exhaust, but we get there faster!
Looking for a better rig...
301TBS
Ontario, Canada
Posted: 04/09/12 06:26pm Link  |  Print  |  Notify Moderator
Not sure what chassis you have, but if it is a Ford, they available thru Dorman. I can get you the part # if you need it.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
301TBS
Ontario, Canada
Posted: 04/10/12 07:47am Link  |  Print  |  Notify Moderator
Looks very similar to what i put in my truck. Got them from Carquest. Think it was a pack of four for about 10 bucks. Might be worth a try. I know they were a LOT less than the complete linkage. Good luck.
hypoxia
Arizona
Posted: 04/10/12 07:26am Link  |  Print  |  Notify Moderator
jimR
This one is made by Denso
