RV.Net Open Roads Forum: Toy Haulers: I broke all 8 studs clean off
Search only in Toy Haulers
 > I broke all 8 studs clean off
2oldman
Winchester WA
Posted: 04/10/12 03:03pm Link  |  Print  |  Notify Moderator
When was the last time the lugs were checked for tightness?
Grillmeister
BBQ TOUR USA
Posted: 04/10/12 03:23pm Link  |  Print  |  Notify Moderator
mapguy wrote:
Not sounding good.... have seen the lug nut shear thing multiple times in my previous career of fleet management.
Do your aluminum wheels have the steel insert for the lug nut? If not they need multiple retorques to get seated. But loose lug nets usually leaves some stud pieces.
What style of torque wrench? Click, beam or dial...
If click -has it ever been stored with adjuster set on a torque value or have you used it to loosen nuts/bolts or have you ever torqued left-hand fastener? Any one of the three requires recalibration or replacement -depending on the tool quality.
I stripped a lug a few years ago with my torque wrench, I found out it was 30% off, 100 lbs was actually 130.
Show me the GRILL and STAND BACK!!!!
SoakedKarma
Reno neh-va-duh
Posted: 04/10/12 04:35pm Link  |  Print  |  Notify Moderator
I would suspect the quality of the studs.. supplier could have easily received batch of offshore lesser quality studs and passed them on to manufacture.. Big problem in the aircraft industry.. Or you were terribly overweight.
DW with her arms crossed is a classic picture. I had to laugh.
Chuck&Gail
In the Colorado Mountains
Posted: 04/10/12 04:50pm Link  |  Print  |  Notify Moderator
Important part was NOBODY HURT. Sorry for your misfortune, but glad it wasan't worse.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Mustang7370
Washington State
Posted: 04/10/12 04:54pm Link  |  Print  |  Notify Moderator
anitajeff wrote:
No the wheel drum was not seize, still would spin. Lugs were tighten by me with a torque wrench, same as the other three. I am thinking factory defect, but could never prove it.
Wheel nuts should always be retorqued after a hundred miles or so. Especially with new hubs. I'll bet they loosened up while motoring down the road.
Chris and Kelli Withers
Ferndale, WA.
powderman426
ohio
Posted: 04/10/12 04:57pm Link  |  Print  |  Notify Moderator
I'm still trying to figure out why you had it towed. You could have taken that hub off, and put new studs in long before the tow vehicle ever got there. You do carry extra studs don't you?? I lost 2 wheels like that and will never be on the road without extra studs. I also check the torque on them frequently. At any rate it looks like no harm no foul.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
Sinecure
South of New Orleans
Posted: 04/10/12 05:11pm Link  |  Print  |  Notify Moderator
Wow. Glad everyone is safe. Why did you load your TV on the flatbed as well? Was the tow driver unable to strap the 5er down to the tow trailer securely?
2007 Wilderness 3102BDS Travel Trailer
2006 GMC Sierra 2500HD 4x4 LBZ Duramax Diesel
mapguy
Puget Sound
Posted: 04/10/12 05:18pm Link  |  Print  |  Notify Moderator
No way to winch trailer onto lowbed without damage if it was unhitched.
phillyg
Front Royal, VA
Posted: 04/10/12 05:31pm Link  |  Print  |  Notify Moderator
My guess would be defective lugs. It wouldn't be the first time that inferior bolt material is shipped to a final assembler. If that was the case, I'd be very disappointed with Dexter, too. There is a way to have the material tested but it sounds like you left the hub with the dealer.
2002 Keystone Cougar 286, 8,400lbs loaded, pulled with a 2004 F150 Supercrew, 5.4, 3.73 gears. Retired and enjoying life
WhitehouseLV
Big Sky State
Posted: 04/10/12 06:34pm Link  |  Print  |  Notify Moderator
You should have let him hit the overpass and let his insurance buy you a new TH . Actually that was good thinking on your part or the situation could have been a lot worse.
Traveling Whitehouse
2009 Keystone Raptor 380LEV
2008 Ford F350 LB CC DRW 4x4
2012 Polaris RZR Boardwalk Blue LE w/EPS
Motorcycles: 04 Honda 250R, 2012 Honda 70, 08 KTM 50 SX, 08 Honda 50
Quads: 07 Honda Rincon, 2010 Pink Polaris 50
