RV.Net Open Roads Forum: General RVing Issues: Caulk
jamesk1
minot
Posted: 04/10/12 02:27pm Link  |  Print  |  Notify Moderator
Anything wrong with using a good grade of outdoor caulk (silicone) on the seams of my class C. Planning on replacing along the trim on the cabover. The stuff that is on there seems to peel off easy so going to remove it and using clear silicone to replace it. The stuff on the roof apears to be a vulcome caulk and that is in good shape. Just the sides could use some attention. Thanks for any info you can provide.
Jim
donn0128
Pronounced Ore-gun
Posted: 04/10/12 02:41pm Link  |  Print  |  Notify Moderator
Yes, It simply DOES NOT WORK! Use the right stuff or pay the consequences down the road. Dicor is one of the preferred sealants.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Crazy Ray
Monroe,La
Posted: 04/10/12 05:01pm Link  |  Print  |  Notify Moderator
Jim just do a search and read NO SILICONE
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
EricGT
PA
Posted: 04/11/12 05:21am Link  |  Print  |  Notify Moderator
Is this what you guys would recommend?
http://www.amazon.com/Geocel-Corp-26102-Flex-Caulk/dp/B000DZBHAE/ref=sr_1_1?ie=UTF8&qid=1334143229&sr=8-1
Can this be used on all surfaces? MY RV is aluminum, but I also need to caulk the shower walls.
2002 'The Rogue' by Mckenzie div of Monaco Coach
24' E450 chassis, V10, Class C, Single slide
mapguy
Puget Sound
Posted: 04/10/12 05:30pm Link  |  Print  |  Notify Moderator
A quality urethane or polyurethane based caulk rated for the materials on an rv is best. There are some of these at the orange or blue box stores but ProFlex is a better choice. I use 3M 4000UV on my trailer -it is not cheap but rarely needs touch up in the same place twice.
Cheap silicone or latex based products will be "gifts that keep on giving" the first time you need to touch up a crack or void that appears.
therink
Rochester
Posted: 04/10/12 03:00pm Link  |  Print  |  Notify Moderator
Silicone based sealants do not adhere well to plastics or fiberglass. I use ProFlex RV lap sealant on the vertical areas and Dicor self leveling sealant on the roof seams.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
