judelaurenzo25g
Downey, CA
I just tested my thermistor using ohms at 2K setting the reading say .549 ohms. Does that mean Its really 5490 ohms? This is what Im testing
A ship in harbour is safe, but that is not what ships are built for.
Wayne Dohnal
Bend, OR.
The readings are often in k-ohms, so it could mean 549 ohms. Does it change when you heat up and cool the thermistor?
2009 Fleetwood Icon 24A
Honda Fit dinghy with US Gear brake system
LinkPro battery monitor - EU2000i generator
weasel4
Alberta
Does your multimeter show zero when you touch the probes together?
BTC
judelaurenzo25g
Downey, CA
yes... It zeros out
judelaurenzo25g
Downey, CA
Wayne Dohnal wrote: The readings are often in k-ohms, so it could mean 549 ohms. Does it change when you heat up and cool the thermistor?
No, I tested it before I put it in ice water and it was reading the same.
weasel4
Alberta
Is there another lower setting on the ohms scale?
Btc
judelaurenzo25g
Downey, CA
I have a "200"
weasel4
Alberta
Try that and see what it reads
BTC
judelaurenzo25g
Downey, CA
this is the multimeter I have
judelaurenzo25g
Downey, CA
weasel4 wrote: Try that and see what it reads
BTC
When i used the "200" setting it would not register anything at all
