RV.Net Open Roads Forum: Class A Motorhomes: generator servicing
 > generator servicing
lj2654
weeki wachee, florida
Posted: 04/12/12 04:49pm Link  |  Print  |  Notify Moderator
I have an Onan 7500 diesel generator and would like to do my own servicing. Oil, filter,fuel and air filter. Where can you get the items needed to do this.....auto parts store, online? Want to be sure to get the right oil and filters the first time as I havent done the servicing myself yet! Thanks for any suggestions.......
2001 Beaver Contessa Naples 40
2005 Honda CRV Toad
retired AirForce
JcoFS3500
East Central OK
Posted: 04/12/12 05:02pm Link  |  Print  |  Notify Moderator
Local auto parts, online, or your local Cummins dealer should all have or can get what you need. Just get the numbers off your existing filters and they can cross them over if they don't have that brand. I would have them compare those numbers to what the book calls for to verify that the current part numbers are correct. For oil, check your owners manual. If it doesn't say, then I'd personally use Rotella or Delo 400 in a 15W40 weight.
Hope that helps.
'93 Jayco FS3500 TT behind a '92 Dodge D250 powered by 5.9L Cummins
'94 Vogue Prima Vista powered by 8.3L Cummins w/ 6spd Allison
Jim Cindy
Northcentral, PA
Try your local NAPA store. Take the model and s/n's with you. You may be pleasantly surprised.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Jim@HiTek
Gresham, OR, USA
Posted: 04/12/12 05:09pm Link  |  Print  |  Notify Moderator
I took my old filter in with me to Napa and bought one that was about an 1" longer. Checked door clearance first. Did that because the short one Onan specs is difficult to get in & out..even with the special wrench they sell for it.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
revump
Las Vegas
Posted: 04/12/12 06:10pm Link  |  Print  |  Notify Moderator
Purchased all my filters for my generator from NAPA
Bob
chewbear
Mobile in the USofA;currently Ozark, Alabama
Posted: 04/12/12 06:45pm Link  |  Print  |  Notify Moderator
Found out had to move Exhaust pipe to get at fuel filter on mine. 7500 Onan.
2002 Fleetwood Discovery
330 cat. '09 Escape toad.
Kathy & Joe wish you well.
My mind works like lightning,
one brilliant flash and it's
gone. (Maxine)
JetAonly
Ohio
Posted: 04/12/12 06:58pm Link  |  Print  |  Notify Moderator
If you go to the Cummins Onan online store you enter your model and it will give you a parts list which you cross. For example:
http://www.cumminsonanstore.com/store/search.asp
2000 Monaco Dynasty
ISC350
