RV.Net Open Roads Forum: Class A Motorhomes: Tag vs Non Tag
 > Tag vs Non Tag
Mr.Mark
California/Tennessee
Posted: 04/14/12 09:05am Link  |  Print  |  Notify Moderator
RayChez wrote:
The only thing tag axle does is gives you more carry capacity. It also gives you a more stable coach on cross winds. And that is about it. All this BS that non tag axle coaches porpoise is nothing but BS. A forty foot diesel pusher will give you a nice ride and incoming big rigs on two lane roads are no problem. You won't even feel any buffing.
It is also two more tires to buy and it also takes away a compartment, plus most will have a side radiator that takes another compartment space. But they are a must on any coach over 42 feet long.
I have really never experienced porpoising in our coach. One thing that I have noticed about having a tag vs. a rental w/non-tag that we had is that going over speed bumps is a total non-issue when the rear wheels hit it. In the front, you will pop up but when the rear axles go over it, it's very smooth as the tag takes the downward motion as the drive-axle goes over.
So, in theory, I think the pressure of the tag pressing down on the pavement would eliminate forward bounce.
MM.
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
CA Traveler
The Western States
Posted: 04/14/12 09:23am Link  |  Print  |  Notify Moderator
Trap, I understand and agree. But I was trying to point out that CCC numbers don't necesarily mean there is usable space for the CCC.
For example most of the additional CCC in the current rig would have to be added to the tag. Short of using sand bags the cabinet and storage space aren't available for more books, clothes, etc. Monacos CCC are just a numbers game. You should look at storage space and weight distribution, front to back and side to side.
Having said that last summer we had a lot of extra heavy "stuff" and weighed 42K with a max of 44.4K. With 2 5' wide pass through outside storage areas we're good to go and having that extra CCC helps make it all possible.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
squeakkos
parker az
Posted: 04/14/12 01:08pm Link  |  Print  |  Notify Moderator
also they look COOLLLLL
Trap
Alberta
Posted: 04/14/12 02:01pm Link  |  Print  |  Notify Moderator
Ok I get it now, and your right some would be almost impossible to overload.
mdprince
Santa Clarita, CA
Posted: 04/14/12 02:25pm Link  |  Print  |  Notify Moderator
At 41' our current coach both rides great and, can carry and tow everything we need. IF we ever get a larger coach, I would go to a 45' with a tag, without hesitation. I think that would give us the same amount of basement storage we have now. YMMV
2006 Revolution LE 40E
2004 Jeep Rubicon Toad/Brake Buddy or
20' Toy Trailer/Quads 'n Dirt Bikes
CA Traveler
The Western States
Posted: 04/14/12 09:35am Link  |  Print  |  Notify Moderator
I never had any porpoising on my 36' non tag. Some buffing did occur when being passed by a big rig and a 40' would be no different.
 > Tag vs Non Tag
