RV.Net Open Roads Forum: Tech Issues: How to extend battery power
 > How to extend battery power
Page of 7
MrWizard
Traveling
Posted: 04/13/12 10:32am Link  |  Print  |  Notify Moderator
I'm "guessing" the battery is close to 3 yrs old, (same age as tt) and you need a/new battery
in fact two batteries would be better for dry camping
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
jyh818
Chino, CA
Posted: 04/13/12 10:37am Link  |  Print  |  Notify Moderator
If I get two group 24 batteries, how should I set them up? Do I connect parallel? Would my charger in the trailer handle it?
2002 Ford Excursion XLT 6.8L V-10 2WD, 4.30 Limited Slip
Rear Hellwig Sway Bar
2009 Skyline Nomad 260
Prodigy Brake Controller
EAZ-Lift WD Hitch
CA Traveler
The Western States
Posted: 04/13/12 10:38am Link  |  Print  |  Notify Moderator
jyh818 wrote:
Wow. Lot's of responses. Thanks all.
More info:
Group 24 deep cycle. 690 MCA. No furnace used. Left bathroom light on. CPE 2000 inverter gen. Fully charged when we left the other campground with full hookups. Will try another battery.
Refrig set on gas.
Have the battery load tested at a auto store. You have the typical NON deep cycle marine battery. Consider 2 deep cycle batteries either 12V aor 6V. Don't run the light all night, instead get one of the portable LED night lights that turns on with motion.
How do you know it was fully charged? By one of the standard and worthless battery monitors installed by the mfg? The primary purpose of these displays is for the sales person to sell the rig... And then did you use power all day and night?
What charger? Many don't do a good job of charging and may also be inadequate with more batteries. Your gen has adequate power.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
CA Traveler
The Western States
Posted: 04/13/12 10:42am Link  |  Print  |  Notify Moderator
2 12V batteries are connected in parallel. 2 6V batteries are connected in series. In both cases you will now have 200AH+. You'll need an adequate charger.
clinthia
Flathead County, Montana
Were you using a lot of juice prior to going to bed?
Never mind
2007.5 Dodge 3500 4X4 Crewcab with 6.7 Cummins
2004 EC950 w/ slideout
2 Costco 6 volts
Yamaha EF1000IS
Kyocera solar panel
GO POWER 300 watt 12 volt PSW inverter
TorkLift tiedowns with Fastguns
Timbrens
Homemade bumpstops
The Schnauzers Madeline & Genevieve
jyh818
Chino, CA
Posted: 04/13/12 10:47am Link  |  Print  |  Notify Moderator
Had the radio on from 7 to 9 pm. Should have ran the generator until 8pm. Now I know.
Had just bought the generator a few days ago for this dry camping. It holds a gal of gas. How long would this last? Manual does not say anything about duration.
skipnchar
Topeka or somewhere else
Posted: 04/13/12 10:53am Link  |  Print  |  Notify Moderator
If you are running the furnace at night then your only actual solution is to add more power (either a stronger battery or additional battery). Dry camping with furnace use is not very practical with a single group 24 battery and even two is marginal.
Good luck / Skip
Crazy Ray
Monroe,La
Posted: 04/13/12 11:08am Link  |  Print  |  Notify Moderator
Google 12Volt side of life and read and learn. JMO
RET ARMY 1980, DW Donna , "Tiny" (furkid) . Class A, 2007 Bounder 35E, Ford Chassis, 4 SAMS 6VOLTS,405W Solar,TriStar 45 Controller,1750W INVERTER, YAMAHA 2400, TOW: Honda CRV. READY BRAKE. "Living Our Dream". NASCAR FAN 14,18,20,11 LOVE CO & NM
MrWizard
Traveling
Posted: 04/13/12 12:19pm Link  |  Print  |  Notify Moderator
that generator will run approx 7 hrs or more while "just charging batteries"
using the microwave etc will reduce that by a small amount
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 04/13/12 12:26pm Link  |  Print  |  Notify Moderator
To hershey,
Don't ever use one burner on low on the stove to cook a large meal like a stew or corn beef and cabbage using the stove is dangerous. Especially when you are not near the stove in the kitchen or living area, but well away from it, in the bedroom with a window cracked ;-)
Page of 7
