RV.Net Open Roads Forum: Truck Campers: Drafting
 > Drafting
Page of 5
bcbigfoot
Okanagan
Posted: 04/15/12 09:17am Link  |  Print  |  Notify Moderator
Matthew_B wrote:
Mythbusters did a segment on drafting. They found that it didn't make much difference until you were around 10 feet back. That's WAY to close to ever consider doing.
I'm sure that is true for a car that has a 24 sq. ft. frontal surface area and a drag coeffient of .28. However our TC's have a frontal area of 104 sq. ft. and a drag co efficient in the .75 range. That makes for well over 10 times the aerodynamic drag.
2002 Dodge 3500 2wd dually, cummins, 4.10 gears, 10500gvwr, Rancho 9000's shocks
2005 Bigfoot 259.6E, 80watt solar, eu2000 Honda gen., 2x group 31 AGM bats., 7100 btu aircond, electric rear step.
covered wagon
Posted: 05/27/12 08:32am Link  |  Print  |  Notify Moderator
With a 45 mph side wind, I found it better to be behind a big rig as he cuts a wind wake behind him. Always more than a safe distance away, I found it made for easier driving in those type of conditions.
sirdrakejr
Las Vegas, Nevada
Posted: 05/27/12 10:05am Link  |  Print  |  Notify Moderator
If there is a direct 45 MPH side wind and you are behind a truck, that side wind will negate and advantage that drafting would give you. You would have to be very close to the truck to see any affect from the truck.
When flying a plane using vectors, one can see that a 45 MPH side wind makes a real difference on a plane. But if on the ground, that wind will certainly be so fast to the side that you will feel turbulence but not any advantage from the truck.
Safety still requires a safe distance from a truck to drive safely.
Frank
kedn
Ks
Posted: 05/27/12 10:16am Link  |  Print  |  Notify Moderator
Not in a TC but I came across Ks behind a double towing big rig for most of a tank of gas, about 2 seconds behind him and was getting a couple mpg gain. Thats on top of a 7mpg normal. But I never could get the same nice spot behind anyone else until I met up with him again a few hours later and got back in that same routine until he turned south at Salina. Something about his setup worked for me, I was comfortable there, and didn't have to crawl up his behind. Actually made the time go faster for me concentrating on how old dominion makes the world on time, I mean concentrating on keeping my distance and keeping track of my escape route being clear if he should slam on the brakes etc.
'05 JayFlight 29BHS
'00 Excursion Limited, V10, 4.30
or
'01 F350 Crew Cab, V10
bka0721
Republic of Colorado
Posted: 05/27/12 10:28am Link  |  Print  |  Notify Moderator
If it was a prudent thing to do, I suspect many truck companies would encourage their drivers to team up and drive in drafting style, as earlier mentioned. With the amount of road debris, that needs to be avoided, and possible damage/injuries from it, I would not do it. Yes, I have done it with my truck and race trailer, but only because I wanted to eke out the last few drops of fuel to get to a fueling station at Green River, Utah. (The station I had planned on stopping at was closed.) With a top heavy vehicle, such as my Truck and Truck Camper, I would not be able to do the maneuvers I could with a Gooseneck trailer.
With a choice, I would never do it. It is not worth the risk. It is not even worth talking about the citation one would receive either.
b
08 F550-4X4-CrewChas-6.4LDiesel-206"WB GVWR17,950lbs
09 Lance 1191
600w Solar~8-6vGC2 928AmpH~Tri-Star45/4 MPPT
Xantrex 2000W
300w Solar~2-6vAGM 240AmpH~Tri-Star45/4 MPPT
Xantrex 1500W
08 BMW R1200GS Adventure
09 7X14 Enclosed Haulmark Trailer
valhalla360
No paticular place.
Posted: 05/27/12 11:09am Link  |  Print  |  Notify Moderator
Even with computers it doesn't work safely. They have had the technology for 30-40 years but any lag at all with short distances and you have a rear end.
Tammy Mike & the Bilge Rat (AKA: Diego)
Ford F250 7.3L
1997 Sunnybrook 27' 5er
1995 Gemini Sail Catamaran 34'
Full Time spliting time between boat and 5er
covered wagon
Posted: 05/27/12 11:29am Link  |  Print  |  Notify Moderator
Frank
I discovered that even at a safe distance the big rig did break up the side winds effect enough that whithout him in front it made for more diffucult steering. Not doing anything like drafting mind you, but, getting only an easier steering effect. I understand also what you are saying here but, somehow the big rig did break it up enough to make for easier steering even at the safe distance. Which is always a rule in my driving practices.
* This post was edited 05/27/12 11:44am by covered wagon *
Page of 5
 > Drafting
