RV.Net Open Roads Forum: Truck Campers: Suspension Question
 > Suspension Question
H2oSprt
So. Cal
Posted: 04/14/12 11:27am Link  |  Print  |  Notify Moderator
I've currently have the following on my 2500HD:
Air bags
Stable loads
Rancho 9000s
My issue is while going into driveways I get a lot of side to side roll. It handles fine in most other situations.
I figured I have two options left, installing a Hellwig overload spring (not sure if my stable loads would still work)Hellwig
Or
Replace the springs
OEM Springs
What do you guys think?
04 K2500 HD, CC, SB, 6.0
2011 Lance 830 w/ tent
Honda 2000
campguy3040
Eastern Iowa
Posted: 04/14/12 11:51am Link  |  Print  |  Notify Moderator
Big Wig
2012 Winnebago Vista, Triple Slide Ford F53.
Blue Ox Tiger Trak track bar, RoadMaster Reflex Steering,&
"Free sway bar Fix"
Blue Ox Alpha Tow Bar w/Patriot Brake System
Chevy HHR toad.
wnjj
Cornelius, Oregon
Posted: 04/14/12 12:00pm Link  |  Print  |  Notify Moderator
Or #3: Just go slow into driveways and don't worry about it. It's not like handling issue at those speeds are safety ones.
dadwolf2
Henderson,NV
Posted: 04/14/12 01:39pm Link  |  Print  |  Notify Moderator
Only in the driveway?? wouldn't be a concern for me. Mine does a little sway when going into the driveway at an angle too and otherwise handles great. Wouldn't spend money if it's only a driveway issue.
2005 Dodge Ram 2500 CTD,4X4,NV5600,Pullrite superglide
2005 Skyline Rampage 289
2011 Outfitter Apex 8 (Love it)
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/14/12 01:54pm Link  |  Print  |  Notify Moderator
I would add a rear sway bar. The function of the sway bar is to limit side to side motion of the axle (body roll), which is exactly what your complaint is. The Helwig Big Wig would be a good choice.
If you're otherwise happy with the suspension, there is no need to do anything with the springs. On a brand new 2011 truck, there should be no need to replace the springs with equally rated stock replacement springs. Your springs shouldn't be worn out on this new of a truck.
If replacing the springs, a heavier duty than stock spring would be the right choice, otherwise, you're not accomplishing anything but replacing a perfectly good spring with an exact equal one. No gain.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
dadwolf2
Henderson,NV
Posted: 04/14/12 02:57pm Link  |  Print  |  Notify Moderator
Another thought is that under the driveway conditions you mentioned, I think it's more front sway than back.
kohldad
Goose Creek, SC
Posted: 04/14/12 07:26pm Link  |  Print  |  Notify Moderator
If it's just driveways, I wouldn't worry about it.
However, are your airbags plumbed seperately. If not, the air will flow from one to the other and is more noticeable at slow speeds.
Otherwise, add a rear sway bar. It is designed to reduce the side-to-side roll.
You already have the airbags to help carry the weight which is what the springs are designed to do.
Photo Albums
2004.5 Ram 3500 4x4 Quad-Cab SRW CTD 6-spd, XD9000 winch
2004 Lance 815 (an upgrade from my prev 2005 35' fiver )
DW (homemaker), 1 DD @ Clemson in Civil Eng (Dec 2013) w/SIL, 1 DD Tech Grad (home but employed), 2 DFs (meow)
billtex
RI
Posted: 04/14/12 07:44pm Link  |  Print  |  Notify Moderator
Air bags
Stable loads
Rancho 9000s
Or
Replace the springs
OEM Springs
I figure you have one more option; reduce the psi in the airbags...
2006 Chevy D/A CC
Adventurer 810WS
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/14/12 06:43pm Link  |  Print  |  Notify Moderator
I will look into the Big Wig, the truck however is not new, it's an 04 with nearly 100k miles on it.
I see. I read your signature wrong. Mistook the 2011 camper for a 2011 truck.
In that case, a new set of heavy duty springs may be a good idea, in general, if you feel it needs a little more spring when driving with the camper. I wouldn't change the springs just for the driveway issue though.
How old are the shocks?
H2oSprt
So. Cal
Posted: 04/14/12 03:29pm Link  |  Print  |  Notify Moderator
