RV.Net Open Roads Forum: Tech Issues: Monitor for tanks and LPG Gas
 > Monitor for tanks and LPG Gas
dalefuji
Milton, Pa.
Posted: 04/14/12 06:06pm Link  |  Print  |  Notify Moderator
I have a monitor panel that was working fine. I went to de-winterize it and the monitor panel that gives readings for LPG, Fresh water, Holding and Gray water does not give me reading when I press the "test" button. The water pump switch and the the hot water switch for gas both work. The fine print at top reads "Customed Designed by KIB" (not sure of the KIB) It also has reading scale for the batteries (L,F,G,C)
I checked the two on boad batteries and they seem fine.
I am looking for help or any ideas. Do you think the test switch is bad?
pulsar
Lewisville, NC
Posted: 04/14/12 06:36pm Link  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2chiefsRus
USA Somewhere
Posted: 04/15/12 06:17am Link  |  Print  |  Notify Moderator
Do you also have similar monitor in the wet bay? When our inside display stopped working, we swapped the board out with the monitor in the wet bay to determine it was the board. We ordered a new board from KIB for under $40 including shipping.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2003 Odyssey
Fulltime since October 2007
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
mr300ce
Mojave Desert, Ca
Posted: 05/13/12 03:31am Link  |  Print  |  Notify Moderator
On mine, one of my switches went bad. Replaced for about $2.
Fulltime livin' & lovin' it in '94 Bounder 32h.
Chevy 454ci Retire in 3yrs.
dalefuji
Milton, Pa.
Posted: 05/13/12 07:24am Link  |  Print  |  Notify Moderator
I called KIB and they sent me new switch "at no cost" and that corrected the problem. A+ for KIB, they stand behind there equipment.
CT_WANDERER
E. Lyme, CT
Posted: 05/13/12 08:49am Link  |  Print  |  Notify Moderator
I have a fuse to mine, did you check to see if you have one? Then I would look at the switch. Just a quick thought. Gary
