avvidclif1
Does anyone have an idea why the truck mfg's decided we need to have a truck 6' (facetiously) off the ground. They keep getting taller and taller. Consequentially the trailers get higher and higher, flipped axles etc. 3 steps to get in the trailer. Hitting max allowable height on trailer (13'6")
Has anyone looked into lowering the truck and then lowering the trailer for a more stable ride? I'm not talking about a "lowrider" but a 2-4" drop would be great. At least in my opinion.
Thoughts?
Clif & Millie
Ozzie half a dog tall and 2 dogs long
2009 Ford F350 SRW CC Lariat 6.4 Diesel
2011 Crossroads Cruiser CF285RL Patriot Edition
pressure_welder
brandon
i am definatly in agreeance! just bought a new 2012 denali dually last october, didnt even think about it when i purchased it about the height. Thats the main reason i bought this new truck as my last duramax had an 8" lift on it. First think i had to do after i bought the denali was have a 6" lift put on my camper so i could get adequate clearence, with every possible adjustment i could make while still keeping the camper as level as possible ill i have from the bedrails to the bottom of the camper is 6" MAX. Which is fine for me as i dont offroad, but youd figure an gm would know a good percentage of us that buy their duramax's pull campers/fifth wheel style hitched trailers. Nonetheless the trucks a beast, but wasnt expecting to do such a lift on the camper to make it useable.
2012 Duramax Denali Dually
2003 Triple E topaz 29' luxury touring edition.
1850 crestliner sportfish w/ 150 optimax
Old-Biscuit
Across the USA
Well trucks use to come with 15" tires........then 16"....then 17"......then 20"
That along with the higher cargo capacities required stiffer spring packs.
Then add on 'styling'.........
j2catfish
Newport, NC, U.S.of.A.
I dropped my 2008 Chebbie rear end by using drop shackles. It lowered it enough (3") that I have the needed bed clearance and my 5er is almost level when towing. My manufacturer says that "slightly nose up" towing is OK. Mine is my defination of "slightly high"
K3500; Teton Homes 5er;
Native Texan - Transplanted Tar Heel
Retired USMC Mustang (LDO)
Semper Fi !
donn0128
Pronounced Ore-gun
Marketing. Some weenies at corporate think bigger is cool. Unfortunately they completely fail to take into account ho hard it is to lift 50 pounds over the side and into the bed when they are so high off the ground. All new trucks are totally impractical for everyday use now. Until people refuse to buy them things are not going to change.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
halibutman214
Oregon
If you don't like the height then don't buy it.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
portablevcb
Tijeras, NM
I wish I could lower mine. I needed a 4wd or would have bought a lower truck. We did get smaller wheels/tires when we bought it.
2009 Dodge 2500 Double Cab Cummins
2003 Skyline Nomad 24ft Fiver
Me and Wife
Maggie the Old English Sheepdog
jetboater454
Camping or home
Here is one almost 6' off the ground.They did have to mod the trailer a little.
"If momma not happy ....Who cares.I have my TH AND my toys .
2007 Gulfstream Endura Max 40
2001 Polaris Ranger 4X4
Mod Pics
avvidclif1
halibutman214 wrote: If you don't like the height then don't buy it.
Very helpful post. What are you going to tow a 5er with??? Toyota Prius?
edited 04/15/12 09:30am by avvidclif1 *
bpounds
Whittier CA
Those of you who don't like the tall trucks, apparently only use your trucks in one dimensional fashion. Pulling oversized, overweight, overpriced fivers, and never going off the concrete highway.
Trucks are taller because that's what the rest of us, the majority, need and want. Farmers, ranchers, construction workers, outdoorsmen, hunters, fishers, weekend warriors. And we want to pull fivers too. So that's what the truck designers give us, and the trailer manufacturers have to adapt.
If you don't like it, don't buy one. The MDT are lower. Those might fit your one dimensional purposes better.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
