RV.Net Open Roads Forum: Beginning RVing: Jacking question
 > Jacking question
Browntrout73
Missoula, MT
Posted: 04/15/12 02:29pm Link  |  Print  |  Notify Moderator
So dumb newbie question:
I want to adjust my wheel bearings before we head off on our maiden voyage. Do I need to have the fifth wheel hitched in order to take the pressure off the front stabilizers when jacking up the wheels? Or is it okay to have it unhitched and front levelers down?
Thanks!
CincyGus
Cincinnati
Posted: 04/15/12 03:50pm Link  |  Print  |  Notify Moderator
Thanks!
What kind of adjustment do you plan to make?
All I have ever heard of or done is checking them for wear and repacking them with grease as needed. As far as jacking the fifthwheel, I would hitch it and then jack, just to prevent any chance of bending or binding the front stabs as the angle of the frame changes when you jack it. Hopefully someone w/ a 5er will respond to that part of your question (I have a TT).
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
Chuck&Gail
In the Colorado Mountains
Posted: 04/15/12 05:28pm Link  |  Print  |  Notify Moderator
Mines a pull TT, but I NEVER jack unless TT and TV are connected. If it ever moved .....
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Allworth
Orlando, FL
Posted: 04/15/12 04:15pm Link  |  Print  |  Notify Moderator
Hitched is safest. More to be sure that the trailer doesn't move as you lift it than to protect the front jacks (which are sturdier than you seem to think). With the pin locked in the hitch and the truck in park, it is stable.
Do NOT jack under the axle tubes. They will kink and put the wheels out of alighment. The jack (bottle or floor type) can be placed under the spring perch (the pad that connects the axle to the springs) or directly in front of the front spring hanger bracket (or directly behind the rear spring hanger bracket for the rear wheel). A piece of 2x4 about 8" long between the jack and the frame spreads the load a little if that makes you more comfortable.
I, too, am not sure just what you plan to "adjust". Bearing retainer nuts are either set up correctly or you have wheel wobble. They don't develop end play after they are set.
You are better off to spend your time (and money) getting rid of the cheap tires that come on almost all trailers and getting LT (Light Truck) replacements.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
 > Jacking question
