RV.Net Open Roads Forum: Fifth-Wheels: Double door fridge
 > Double door fridge
Rmcgrath53
Howell
Posted: 04/17/12 04:54pm Link  |  Print  |  Notify Moderator
Randyl81 wrote:
I have a 2008 5ver with a double door fridge, every time we take it out the temp in the fridge part gets to 33 deg, as soon as we put just a few items (already cold) inside the temp goes up slowly until it tops out at 49/50. The freezer works perfect. I take it to the dealer he keeps it a week it works perfect, I have the same problem at other camp sites as well so its not the power. This has been going on over a year.
My question, has anyone else had this problem?
Our fridge was a 2008 that did everything yours is doing. Then It suddenly went out and had to replace the whole cooling unit.
2008 keystone Everest 345s re
2002 F350 4x4 7.3 diesel crew cab dually. 135,000 miles extra leafs.
Banks stinger/ with an edge attitude set at tow
prodigy 3p curt 20k hitch
trail air suspension trail air pinbox
2 e2000 honda w parralel kit
560 watts solar
conmoto
Northern Illinois
Posted: 04/17/12 05:01pm Link  |  Print  |  Notify Moderator
When ours has had the same problem as yours it was because the fans were not turning on in the cooling fins because the connection was loose. There are two fans that must circulate the air in the back when it gets warm.
UnionMan354
Where We Park It!
Posted: 04/18/12 08:02am Link  |  Print  |  Notify Moderator
We too had similar issues with our Norcold. Tried replacing the inside thermister, bought inside fans (highly recommended EBAY) but still didn't perform like we expected. Then in March the unit failed with an ammonia leak and near fire. We decided to replace the cooling unit with a new Amish built unit and have been VERY happy! Check out our YouTube video: Our Norcold to Amish Built Cooling Unit Change-out
Robert & Shelly
2000 American Dream 40' DS
2003 Saturn LW200
Full-timing Class of 2006!
Escapees, ACC/ACA, FMCA Members
http://www.evansrvadventures.com/
remoandiris
Posted: 04/18/12 08:23am Link  |  Print  |  Notify Moderator
My Norcold N1095L is cold in the a.m. when the outside air temp is low, but goes up to 40+ when the outside air temp gets hot, even though the temp inside the 5er is between 70 and 75. These things just aren't efficient or well insulated.
When this on craps out, I'll be looking for a residential unit. If they can stay cold for days at a time with no power following a hurricane, they should be fine for a few hours between CGs.
2011 GMC 3500 Dually
New to me 2006 Jayco Designer 38RDQS
2 Boxers and a Maine Coon
