RV.Net Open Roads Forum: Travel Trailers: Which caulk? Duralink? 3M 4000?
 > Which caulk? Duralink? 3M 4000?
Mxracer532
Washington
Posted: 04/16/12 09:30pm Link  |  Print  |  Notify Moderator
For caulking around the upright seams where the sides meet the front and run to the top. Gonna put Eternal bond or Buytl tape under then scew crown back on the caulk up both sides. Which do i use?
janechucknicodemus
Oregon
Posted: 04/16/12 10:07pm Link  |  Print  |  Notify Moderator
I use and have used 2 different ones , both from lowes or HD . inside DAP 3.0 clear outside DAP Dynaflex 230. Depending on the color you want you can get the Dynaflex in Almond and white. This is a very easy to use, clean up and to me a superior product to a lot of the
'RV"brands.
I carry this every where I go. You would be surprised how many people come up with LEAKS at the worst times, and if you can help them out it is good.
Oh and when you are caulking, run your point towards the seal it makes for a smoother bead, and as always keep a bowl of soapy water to put your finger in to run over the bead. Works great!!!
Cheers and happy fixing.
Chuck
Dandy
NorthEast
Posted: 04/17/12 05:43am Link  |  Print  |  Notify Moderator
I have never used it on my TT but I couldn't imagine not having 3M 4000 on the boat. It is great for outdoor applications.
2009 GMC 2500HD Crew Z71 / 3.73 / 6.0L
2012 Prime Time Lacrosse 318 BHS Touring
Reese WD System with HP Dual Cam
Factory GMC Brake Controller
Factory Receiver Hitch
Factory Tow Mirrors
HappyTrails2U2
Tennessee is home but being held hostage in GA.
Posted: 04/17/12 06:11am Link  |  Print  |  Notify Moderator
I think the majority of people here use Dicor caulking. 2 types - One is self leveling and the other is for caulking around protruding things such as vents and antennas.
http://www.rvwholesalers.com/catalog/dic........ubber-roof-chemical-sealent-13-1315.html
2010 Rockwood Signature Ultra Lite 8315BSS
2003 Chevy Silverado 1/2 Ton Extended Cab
rgolding
Southern Illinois
Posted: 04/17/12 06:59am Link  |  Print  |  Notify Moderator
I have a couple of the Dicor caulking gun size tubes, but was amazed that a smaller tube (like a tooth paste tube) wasn't available to carry for emergency and small repairs.
