ScottG
Bothell Wa.
I sure wouldn't put a ton of heat on a glass lined tank.
Just use your impact wrench - I've done this myself a couple of times.
Scott, Grace and Wesly
H0NDA eu2000i
RayChez
Barstow, Ca. USA
I agree with the impact wrench. I would not put heat on it. Mine was pretty tight, but with a little force and a good socket it will break lose.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
rhochnadel
Colorado
If it is an Atwood there should not be an anode rod, if it is Suburban you should be able to break it loose with a penetrating oil. Good luck!
'05 Keystone Challenger TPK
'01 Chev 2500HD Duramax/Allison
Corgi "Pippin" & cat "Sundance"
fordsooperdooty
By all means use a bit of liquid wrench (etc) on it first.
BTW...Using a flamable substance near an open flame is a no-no!
Then when the water heater is still hot, spray a blast of computer keyboard duster/cleaner on the Suburban water heater anode rod nut. The tank will expand from the heat, and a blast of chilled freon from the can will contract the cold anode rod while you are cranking down on it with a socket or wrench. It works!
jvander
Indianapolis
Liquid Wrench is useless. WD40 is really just a water displacer, not a creep-in oil or a lubricant at all. PB Blaster is pretty good, but the best I've found is Kroil. It makes PB Blaster seem like WD40.
You can only get it online.
1993 Coachmen Catalina 31'
Chevy P30, 454 TBI, Hedman Hedders w/ x-pipe and Jones Full Boar mufflers. Same mileage as stock exhaust, but we get there faster!
Looking for a better rig...
UltraKen
Ohio
Weldon wrote: Just be sure you are turning the anode rod to the left to remove it...counter-clockwise.
Righty, Tighty; Lefty, Loosy
UltraKen
Ex - 1968 Ultra Van
NOW - 1996 Safari Sahara 35' - Model 3530 - Cat 300
Pictures of my Coach
A $93 Rear Camera System
My take on replacing tires
Used MH Checklist
Toad: Dodge Grand Caravan on Tow Dolly or 1981 Vespa on utility trailer
bsinmich
Holland, MI
rgatijnet1 wrote: First make sure that you actually have one. Not all water heaters use the anode rod. My Atwood has an aluminum clad tank and it has a drain plug that is next to impossible to get out, BUT there is no anode rod to change.
On an Atwood you should have a plastic plug that would not seize to the tank.
I have found Kroil at farm supply stores and also at Menards.
2003 Newmar Mountain Aire, Workhorse W22, 2008 Saturn Vue, Falcon 5250, & US Gear Unified Tow Brake
hhornig
Eagle, NE
fordsooperdooty has the right idea. You want to heat the nut and cool the bolt at the same time. I would try dry ice on the anode rod if freon spray does not work. I am afraid an impact wrench might damage the metal to glass seal. Obviously, when you break it loose you will want to leave it in the tank until you cool the water.
FedAgent
Corpus Christi, TX
Just an update. After several days of hitting it with penetrating oil, I got out the impact wrench and set the air pressure on low and gave it a try. Low and behold it came out. Glad I got it out, anode was 3/4 gone.
Thanks for all the tips,
Larry
Larry
2007 Newmar 37 Mountain Aire, 05 Jeep Wrangler,lifted and chipped toad.
Yellowstone National Park seasonal staff.
