RV.Net Open Roads Forum: How much PSI do u run in TV
Search only in Tow Vehicles
 > How much PSI do u run in TV
wvbike_99
West Virginia
Posted: 04/18/12 03:00pm Link  |  Print  |  Notify Moderator
I have a 2010 F 150 Super Cab and amd going to pull a Primetime Tracer about 5750 dry weight. Do u guys run the truck stock tire pressure or increase it a litle. My old RV only weighed 3700 dry so a little difference??
2012 Primetime Tracer 2640 RLS
2010 Ford F Super Cab
5.4 Engine, 3.56 Gear
Factory Tow Package
Equilizer Hitch
Wife and Myself
No Cats or Dogs
rvert10
Utah
Posted: 04/18/12 04:26pm Link  |  Print  |  Notify Moderator
That is a question that plagues us all and think the best answer I can give is call the tire dealer. My dealer has me at 65psi(dually) for towing my 5ver
08 Dodge Mega Cab DRW,6spd auto, Exhaust break, 8'bed conversion (Best mistake I've made)
35' Teton Home Experience 3 slides, its not a trailer its a home
5500 watt generator
and a beautiful Co-piolet
wilber1
Abbotsford B.C. Canada
Posted: 04/18/12 05:09pm Link  |  Print  |  Notify Moderator
What's the hitch weight? How much weight are you putting in the back of the truck? What is the tire rating? What do you mean by stock tire pressure? Does your owners manual or door sticker give loaded and unloaded tire pressures? Hard question to answer.
"Never trust a man who has not a single redeeming vice" WSC
goducks10
Keizer OR
Posted: 04/18/12 05:14pm Link  |  Print  |  Notify Moderator
When I had my stock P rated tires on my 10 F150 I ran them maxed at 44psi. I wanted all the stability I could get. To me the door sticker psi is not for a full load in the truck. It's the empty trucks weight. Load the truck up and air up the tires is what I've always done. Maybe I'm wrong but I've never had a problem with maxed out psi on stock tires when loaded.
ib516
Up here!
Posted: 04/18/12 05:46pm Link  |  Print  |  Notify Moderator
The correct pressures for your truck are on the driver's door post. If you run that pressure, you will be OK up to your max GAWR.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
Tankcar
Santee, California USA
Posted: 04/18/12 06:10pm Link  |  Print  |  Notify Moderator
Hi.
Check the side wall information for the tires you are using. Find the "COLD" pressure requirement.
Check tire pressure about 5am. Which is usually the coldest part of the day.
I keep my tire about 5 pisg lower to than the side wall information.
As the tire roll's the air pressure will expand. Remember the hotter the road temp gets the bigger the tire will try to get.
Also check the weight of you RV it will add heat as well. Make sure your tires can handle the weight. under size tires will give you a pain
KD4UPL
Swoope, VA
Posted: 04/18/12 06:51pm Link  |  Print  |  Notify Moderator
You need to weight the rig and find out your axle weights. Look up the tire manufacturers load inflation table and see how much pressure is required to support the weight you have. That is the only way to know.
Terryallan
Foothills NC
Posted: 04/18/12 06:52pm Link  |  Print  |  Notify Moderator
I max mine out. (current tires 2271 lbs at 44 psi when towing). ( Last set 2601 lbs at 50 psi) when towing. Have had no problem in 30 years. Running at max when towing makes the TV more stable. Even though the TV is not maxed out on weight. Remember. It does not have to carry the trailer, only the tongue weight.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
rvert10
Utah
Posted: 04/18/12 07:02pm Link  |  Print  |  Notify Moderator
Is this for all tires or the stock tires, if so, then I and maybe others get wrong info. from dealers.
wilber1
Posted: 04/18/12 08:29pm Link  |  Print  |  Notify Moderator
If in doubt, better to err on the high side but no more than the max sidewall pressure.
