RV.Net Open Roads Forum: Class C Motorhomes: HELP!!! Greyhawk 31 FS
 > HELP!!! Greyhawk 31 FS
Mike& Rose
Lake & Horse country,Blackstone Valley MA
Posted: 04/19/12 05:57am Link  |  Print  |  Notify Moderator
Opps! What was I thinking Sorry
See you on the road!
pianotuna
Regina, SK, Canada
Posted: 04/19/12 06:23am Link  |  Print  |  Notify Moderator
Hi,
I'd be suspicious of the transfer switch. They often get cranky and have burned contacts inside. If I had one and it failed I'd eliminate it and go to a manual system.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
skyman1972
Beaver, PA
Posted: 05/06/12 09:31pm Link  |  Print  |  Notify Moderator
Update.... Made it to Disney and the transfer switch melted away. This was a recall issue that I thought was taken care of with the dealer. Either way I had a mobil repair guy come and reroute power so shore would work. I now need to go to a dealer and get a new transfer switch installed. Oh and ft. Wilderness was great!
sjn7708
illinois
Posted: 05/07/12 07:44am Link  |  Print  |  Notify Moderator
i found out the hard way that you can easily burn out the transfer switch if you dont stop the generator before hooking up to shore power or vice versa. when it happened to me, i got shore power but no generator power. transfer switch changed under warranty and all was well.
