RV.Net Open Roads Forum: Tech Issues: Slow propane leak update...
 > Slow propane leak update...
Smax
Rochester, NY
Posted: 04/19/12 11:50am Link  |  Print  |  Notify Moderator
Like others have said. That's a lot of propane, and you should be smelling the leak. The only place I can think that it would vent where you would not smell it is up the fridge vent.
Just a thought.
Max
2010 Silverado 2500HD Duramax/Allison Crew
2000 25' Sunnybrook
2010 Honda SH150
shutdown
In The Dog House
Posted: 04/19/12 12:16pm Link  |  Print  |  Notify Moderator
OK just be clear....i am NO LONGER LOSING A TANK IN 5 DAYS. i did smell, find and repair that leak.
i am losing the contents of the lines in 6 hours. NOT A whole tank. I pressurized the line then turned off the tank. 30 mins later i still had gas, an hour later i still had gas. 6 hours later no gas.
Chris Bryant
DeLand, Florida, USA
Posted: 04/19/12 02:29pm Link  |  Print  |  Notify Moderator
You will not have a perfectly sealed system- the standard is for the system to hold an 8" wc reading for 3 minutes with no change in pressure (8" because the test is commonly done at the stove, which is regulated to under the 11" wc, plus to make sure the service valve is not leaking). With the modern solenoid valves, you will have some leaks- they just are small enough to be no danger.
-- Chris Bryant
My RV Service Blog
The RV.net Blog
