RV.Net Open Roads Forum: Truck Campers: getting leveled, is there a "best way"?
 > getting leveled, is there a "best way"?
Page of 6
synergy_58
JBER, Ak (Anchorage)
Posted: 04/19/12 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
I'm out learning my new rig and trying to figure out the best way to get leveled.
It's been suggested that I use these...
http://www.level-trek.com/product.php
What do you use?
With a TC/truck, do I use those stick on levels?
Do I use the jacks to level the truck, thus lifting the load slightly, or is that not the way to do it?
I drove up on a few 2x6's, got the truck slightly leveled but I could still feel that I was dwon too far at the head...this is in my driveway for now.
Any guidance on how you do it is greatly appreciated!
JoeChiOhki
Sauvie Island, OR
Posted: 04/19/12 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Your camper should have levels on it, if not, it might be wise to get a couple and place them on the camper after getting it perfectly level.
I usually use chopped 2x6s stacked up to drive up onto to level out. I also carry some plywood squares (3/4" thick) as well for when I need less than the thickness of a 2x6.
CB Channel 17 Redneck Express
d3500ram
colorado
Posted: 04/19/12 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
I use wood blocks and I have gotten used to surveying the terrain ( seeking the most reasonably level available) and just adding a few under only 1 or 2 tires at the most.
On one instance where I parked the site was less than ideal and I found out how well it did with the articulation of the suspension. I posted here about it: Leveling the camper: suspension articulation & heavy camper. This was by far the most out-of-level site I have parked... but...
...I was amazed at how well it leveled out without "micro-adjusting" the blocks! I like the cheap KISS prinipal of wood blocks...
I have heard that those RV Lego type levelers can break, but I am not knocking them.... just never used 'em.
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
2008 NorthStar Arrow short bed.
USMC2010
Arizona
Posted: 04/19/12 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
I tried the stick on levels and did not like them. I take a 6" level with me and place it on the middle of the floor and make my adjustments. This is for dropping the camper which I do pretty much every time. On the truck I have several squares of plywood that I use to drive up on.
2002 Chevy 2500HD LS Extended Cab 4x4 6.0 gas 4.10 rear SWB
Firestone Ride-Rite
2007 Lance 845
MSgt USMC retired
bedrocker
lompoc ca
Posted: 04/19/12 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
I put a bubble in the fridge and level
it using lynx leveling blocks
AnEv942
CA
Posted: 04/19/12 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
Use 2 stick on bubble levles on left rear corner-use for lowereing raising camper. At camp-simple wood 2X6s-if needed, carry six to poasition truck. Can sight both direction with levels-if not off loading release tiedowns if needed to levle camper with jacks.
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
kerry4951
East Central Pennsylvania
Posted: 04/19/12 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
Heres what I use. They offer varying degrees of lift. I carry 4 of them since I have a dually. On a SRW truck 2 should be fine. They store well in my slide out tray so they are always handy to get at. Never had any cracks or breakage.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
kcabpilot
CA
Posted: 04/19/12 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
I use 2x6's and then the air bags after which I lower the rear jacks for stabilization and can get another inch or so of leveling out of them. For an indicator I open the door halfway and let go. If it stays there I'm perfectly level (or close enough)
1994 Lance 990 on 1997 F350 PSD Dually "Rhino Haunches"
woodhog
NS
Posted: 04/19/12 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
We carry short pieces of 2x6 , also around here there are always a few rocks you can throw under the wheels, we have a 12 volt DC fridge and don't really pay much attention to leveling.
2004.5 Dodge 4x4 SRW Diesel, 245/70R19.5 Michelin XDS2, Bilstein Shocks
Torklift Stable loads, BD Steering Stabilizer Bar, Superchips "TOW" Programed,Rickson 19.5 wheels
2006 8.5 Northstar Arrow Longbox 200 Watts Solar, LED lights.
12 Volt DC Fridge.
dadwolf2
Henderson,NV
Posted: 04/19/12 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
I use the same yellow tri-leveler blocks as Kerry4951 and use a cheap 6" torpedo level. When I'm boondocking, quite often a couple shovels of dirt moved is quick and simple.
2005 Dodge Ram 2500 CTD,4X4,NV5600,Pullrite superglide
2005 Skyline Rampage 289
2011 Outfitter Apex 8 (Love it)
Page of 6
