Need owners manual, installation and or service guide for Magic Chef microwave/convection oven model M71C-10 (1988) installed as OEM HR and other class A's in the day. Mine suddenly quit working , no power, no clue?
Any advise would be appreciated . Also would like to hear anyone's experiance with replacement units and where available?
"KEEP THE GREASY SIDE DOWN" On and Off Again Full Timer, Workamper, 43+ years of camping experience, 21+ years towing 5'ers.
New Toy, 1988 Holiday Rambler Imperial, Class A, 34CS,P30 454V8 Chevy Chasis, Onan 6.5, Nisson Xterra Toad.
You said it stopped working. Is there no power or does it shut off at 59 seconds......Assuming it doesn't work at all...Check first to see if your OUTLET is live. Plug something else into it or use a meter. If it's still hot, then you can proceed with trouble shooting the microwave. If not, then first check your inverter to make sure there's no breaker popped. I've even gone so far as hooking up an extension cord to the microwave and see if it works. Rule out the easy stuff first. Does the front TV work......Remember the microwave and TV are usually on the inverter circuit.....Dennis
Dennis and Debi
Chevy HHR W/ ReadyBrute
Fourth Year Full Timing Click here to view our travel blog
I had that problem with a Magic Chef several years ago. There was a blown fuse, like an old automotive, glass tube fuse. I replaced it and never had another problem.
Paul
Paul & Helen
2002 Winnebago Journey DL
1999 Jeep Cherokee toad
Yellow Lab, Jodie, Chocolate Lab, Coco , and Lab/Golden mix, Sandy.
FMCA 98905
http://ptempesta.blogspot.com
