RWDIII
Casa Grande,AZ; Lakewood CO
Heading out to the colorado river near Hoover dam and the new bridge between Ariz and Nev.Just installed a scan guage in the 06 F150,hope to improve my 10mpg avg and will let me monitor the water temp.Was disappointed that on my year Ford could not moniter trans temp or oil temp.
2006 F150 4x4 tow 7200 GVW,9200 tow pkg
2007 Fun Finder 189 3500 lbs,380 toung wt.
2006 F150 4wd 7200gvw,Lt275-65-18,Scan Guage,Garmin,flowmaster,load levelers,Firestone work rites, sat radio 50s on 5 or outlaw country
2013 Bronco 800
1200/1500 champion
Mostly Boondock
ritterjw
Albuquerque,NM
I use the a Scan Gauge for my O6 F150 to monitor the the trans temp. It has been several years ago that I set it up. I believe I went to the Scan Gauge website and found info on how to program it. Wish I could tell you more.... But I have sleep a few nights since then and age does do wonders to the old gray matter.
zigzagrv
Nazareth, PA
MitchF150 wrote: How is a ScanGauge going to help your mpg??
Mitch
Lightens your wallet. Less weight=better mpg.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
'95 Tracker toad
ib516
Up here!
It's called the XGauge function. It's on their website.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
goducks10
Keizer OR
ib516 wrote: It's called the XGauge function. It's on their website.
x2, I had an 08, same as an 06 and had the tranny temp, water temp rpm's and whatever else on my scangage.
MitchF150
Washington, the State
Mitch
*Anything I post is for entertainment purposes only and what usually works for me.. Your Mileage May Vary..
RWDIII
I returned from the trip and my avg MPG is 10.7,low of 9.8 and hi of 11.5.The scan guage helps by giving accurate feedback.The 06 has no tow haul and I found by shifting out of OD earlier on a hill helps.Desert Capt. reported 8% increase,mine is 7% on first trip.
Also found out my water temp is very good..never above 198 avg is 195 towing and 189 not towing,and it was 101 in Casa grande when I returned.I also found my best speed was 63 MPH towing.
I also found out in 2006 they used both the old and new protocal.Mine has the older one .the newer one will give trans temp
Randy
lbrjet
Liberty, IN
Pretty simple. The instant MPG readout gets me to the speed where I get the best mileage. Maybe 60, maybe 65 it all depends the conditions.
2010 F250 4X4 5.4L 3.73 LS
2011 Flagstaff 831FKBSS
Equalizer E4 1200/12000
K Charles
Connecticut
Modern Math
edited 04/21/12 07:23pm by K Charles *
