RV.Net Open Roads Forum: Fifth-Wheels: Another Lippert Frame Failure
 > Another Lippert Frame Failure
Kenny3p0
Travelling Full Time
Posted: 04/20/12 07:06pm Link  |  Print  |  Notify Moderator
Here is what happens when a Lippert Frame fails on a Keystone Cougar. Look at the damage first then the repairs.
http://www.flickr.com/photos/kenny3po/
2005 Ram 3500 DRW Quadzilla
2009 Keystone Cougar 316QBS
joebedford
Jasper, Ontario
Posted: 04/20/12 07:23pm Link  |  Print  |  Notify Moderator
From the rust, I'd say that failure was in the making for a long time.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
downtheroad
Pacific Northwest
Posted: 04/20/12 07:44pm Link  |  Print  |  Notify Moderator
I'm not seeing an excessive amount of rust.
From a very quick look at the pics...appears to be more of a metal tare/failure rather than a weld failure..
Again, as I have posted before when this comes up...ALL the frame failures I have ever read about were on 5th wheels - none on travel trailers...??
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
chuggs
Posted: 04/20/12 07:54pm Link  |  Print  |  Notify Moderator
I'm sure glad that Lippert engineers don't design wing roots for commercial airliners. Whoah...
They know that area flexes...which work hardens the steel...and eventually it gets a tear. Those joints need gussets and stiffeners welded in to help distribute that stress. The metal is just too thin to handle that kind of repeated flexing.
pcm1959
home
Posted: 04/20/12 07:55pm Link  |  Print  |  Notify Moderator
It's only 3 years old, too! Were you traveling with the fiver when it happend? Did it damage your truck? Phillip
2011 Silverado Crew 3500 SRW Duramax/Allison
2011 Carriage Cameo 31KSLS
Jacksonville, FL
garysol
Avon Ohio
Did Lippert give any assistance with the repairs? Was there any interior damage?
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
conmoto
Northern Illinois
Posted: 04/20/12 07:56pm Link  |  Print  |  Notify Moderator
Seems as though those pics get recycled on a regular basis.
chuggs
Posted: 04/20/12 08:06pm Link  |  Print  |  Notify Moderator
It looks like they just butt welded the pieces in again. I would have liked to see them put a reinforcement plate at the corners of some of those 90degree butt welds. Imagine a flat piece of steel shaped like a football. Bend it in a brake to 90 degrees... Stress relieve the bend with a torch. Place against the structure that you're reinforcing. Run a bead of weld along the entire edge of the gusset. It spreads out the forces...and you're not depending on a weld to hold at a 90 degree angle. Welding leave the metal brittle from the heat. It's not really practical to hold a torch in there an nomalize those joints. So welding in a gusset...where the bend has been annealed would certainly help out.
I'm kinda suprised that Lippert doesn't have some real engineers design a Reinforcment kit for mending and reinforcing their frames. They've got this cool technology these days called Finite Element Analysis... The could figure out WHY these things are breaking and come up with a suitable fix. They just need to fork out some bucks to have an engineering consultant come in and do the design work for them.
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/20/12 08:26pm Link  |  Print  |  Notify Moderator
They should have welded the rectangular tube all the way around. Where the vertical welds end and don't wrap around the bottom is the next place a crack can start.
I also agree with what Chuggs said above about welding in gussets in the corners.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
Shrek51
Houston,Tx
Posted: 04/20/12 11:07pm Link  |  Print  |  Notify Moderator
As garysol asked. Did Lippert help with any of the financial costs involved?
