RV.Net Open Roads Forum: Towing: Eaz lift shank compatibility?
Search only in Towing
Open Roads Forum  >  Towing
 > Eaz lift shank compatibility?
LoudDog
Washington
Posted: 04/22/12 05:14pm Link  |  Print  |  Notify Moderator
I bought a new truck and I need to get a new shank for my WDH. Are any shanks compatible with Eaz Lift of am I limited to just Eaz Lift shanks?
TV: 2012 Ram 2500
TT: 2010 Surveyor SP189
Awesome wife and 2 wonderful border collies
jerem0621
Sequatchie, TN
Posted: 04/22/12 05:59pm Link  |  Print  |  Notify Moderator
You are good to go. Shanks are pretty universal.
I have a Husky WD shank with my Draw-Tite hitch head.
Thanks!
Jeremiah
TT: 1995 Layton 2910
Tow Vehicle: 1999 F-350, v10, 2wd, Crew Cab, Dually
Hitch: Draw-Tite Trunnion WD Hitch
Sway Control: Valley dual friction sway control
Brake Control: Tekonsha Voyager
"It's Kind of Fun To Do The Impossible"
~Walt Disney~
LoudDog
Washington
Posted: 04/22/12 09:18pm Link  |  Print  |  Notify Moderator
So the hole spacing should be 1.25" on center on all?
jerem0621
Sequatchie, TN
Posted: 04/22/12 09:42pm Link  |  Print  |  Notify Moderator
I have talked to Reese and Husky about this and they both said that for the most part, WD shank holes are built on a somewhat industrial standard.
My experience says yes, I have two shanks, One extended drop shank from Reese and one standard Husky shank, they are both drilled the same. I haven't measured it but I can tomorrow.
Thanks!
LoudDog
Washington
Posted: 04/22/12 09:55pm Link  |  Print  |  Notify Moderator
Thanks, looks like I have options then. Does the length of the receiver mean much other then distance between truck and trailer?
The one that seems to work out has a 9" length and the one I have has a 10" length.
