RV.Net Open Roads Forum: Class A Motorhomes: Newmar, Monaco, American Coach
 > Newmar, Monaco, American Coach
stuartvt
Williston Vermont
Posted: 04/23/12 06:26pm Link  |  Print  |  Notify Moderator
Hello everyone,
My wife and I are planning on buying a used DP over the next one year. We will be planning on fulltiming. At this moment we are interested in Newmar Moutain air or up), Monaco (Dynasty or up) or American Coach (Eagle or Heritage). I would like to get input on comparing construction quality and pros and cons of each brand. We are looking at 2007 to 2009 model years.
Also, would you think it is worth buying older in order to get a higher model on the food chain. For instance, would it be worth buying a 2007 Heritage vs. a 2009 Eagle, Essex vs Mountain air, etc.
Thank you all in advance for your advice,
Stuart
gemsworld
Sunny Southern California
Posted: 04/23/12 06:30pm Link  |  Print  |  Notify Moderator
I owned a 2008 40' Monaco DP and would not recommend a Monaco product. Go with Newmar or Winnebago. Good luck!
Mr.Mark
California/Tennessee
Posted: 04/23/12 06:40pm Link  |  Print  |  Notify Moderator
Since you are looking for a used unit, maintenance is the utmost importance. Personally, I think all brands that you mentioned would be good choices. Which ever unit has the best floor plan and is in the best condition should be moved to the top of your list.
A 2007 most likely will not have a diesel particulate filter like a 2008 and 2009 unit. We have the DPF and have had no problems at all with it. We burn clean saving the environment. If you have ever been to LA, you will know what smog looks like and you wouldn't want to contribute to it.
MM.
* This post was edited 04/23/12 06:59pm by Mr.Mark *
Mr.Mark
2008 Monaco Dynasty, 42.2 ft., 4 slides, 425 hp clean-air Cummins diesel
2013 Honda CR-V EXL, AWD, w/Nav, SMI Air Force One vacuum-assisted braking
rheavn
Posted: 04/23/12 06:43pm Link  |  Print  |  Notify Moderator
Stuart,
Consider buying the most quality you can for your dollar. Have you considered a 2001/2002 Newell? Same money you are looking at spending, but you would be moving to the top of the food chain.
Steve
Newell
Green D
Van,Tx
Posted: 04/23/12 06:54pm Link  |  Print  |  Notify Moderator
All good brands you have picked, I would look at the 2009 up in the American Coach line for a couple of reasons one being the front axle being over weight. This problem is not just with the AC products either.
Another reason I like the 2010 is they have a newer cleaner burning Aqua Hot System.
Oh and another for the 2010 is the chassis has been slightly changed to allow way better height to the basement storage areas.
Also 2009 ups res fridges are more common and they work great.
I have had very good service with my new AC and great tech support from the company.
Eric
2011 American Tradition 42p
Silverleaf
Pressure Pro
00 Jeep GC
Honda GL1800
2050SS Bayliner
Twomed
FL winters and then somewhere cool
Posted: 04/23/12 07:23pm Link  |  Print  |  Notify Moderator
The hunt is great. Livability and construction is as important as brands, maybe more. There are some key years in all three brands with regard to interior ceiling heights, awning packages, electronics, appliances, tire sizes, genset sizes etc. Functionality...spend smoe time making ali these systems work, some are poorly designed to the point of just plain dumb!! Some archived, floorplanss, brochures exist online, you can write for others. IMO this should all be part of your hunt. Enjoy the ride...
Happy Trails
06 Monaco Dynasty
07 Hummer H3
FMCA 279843
The Texan
Meridian, Idaho
Posted: 04/23/12 07:33pm Link  |  Print  |  Notify Moderator
At 40', you didn't own one of the models he is talking about. Monaco builds a very high quality coach in the models he is referring to.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
gemsworld
Posted: 04/23/12 08:00pm Link  |  Print  |  Notify Moderator
Let's just say, based on my own personal experience, in 2008 Monaco was pushing less than acceptable products out the door. The larger and more expensive units have more bling but workmanship and many of the materials come from the same place. My advice to the OP is do his homework thoroughly before plunking down his money on ANY brand.
rvrepairnut
bc
Posted: 04/23/12 08:04pm Link  |  Print  |  Notify Moderator
dollar for dollar buy a 2006-2009 era Country coach
wa_desert_rat
Central Washington State
Posted: 04/23/12 08:07pm Link  |  Print  |  Notify Moderator
Don't overlook the Foretravel coaches. Very high quality of workmanship, highest quality materials and a manufacturer that is still in business. A good web site to check out is www.motorhomesoftexas.com.
Craig
