RV.Net Open Roads Forum: Crew Cabs are apparently not for carrying Truck Campers
 > Crew Cabs are apparently not for carrying Truck Campers
Page of 9
SoCalDesertRider
Arizona desert
Posted: 04/27/12 09:10pm Link  |  Print  |  Notify Moderator
egarant wrote:
SoCalDesertRider wrote:
If you want to carry an extremely heavy camper on a crew cab truck, get an F450/550 or Dodge 4500/5500 cab/chassis crew cab truck. The cab/chassis trucks have 15,000-19,000 GVWR and 11,000-14,000 RGAWR. Plenty of weight carrying capacity to carry the very heaviest campers ever made, and then some...
Yes, that is the best solution, but at a much greater cost because you don't get a truck bed. I went online, called a service that makes a custom utility bed for your truck camper....$10,000. So add that cost to the equation.
The problem I have is that the truck camper industry is making truck campers of such enormous weight that the largest ones are not even close to being legal to carry on the highway with any 1 ton truck.
No amount of sway bars, air bags, Rancho shocks, stabil loads can legally change that.
I want to be able to drive down the freeway and not worry about me or YOU swerving to miss a blown out tire in the road and not losing control of 5,000 lbs of cargo.
A custom utility bed isn't needed to haul a truck camper on a cab/chassis truck. Sure, you can buy one if you want to, but a much cheaper off the shelf flat bed will haul the camper just as well. Add some under-deck or above-deck tool boxes to the flat bed for more storage capacity.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
SoCalDesertRider
Arizona desert
Posted: 04/27/12 09:22pm Link  |  Print  |  Notify Moderator
Why do that when a 3500 will more than carry the weight? I would think that a payload capacity of 5905 lbs. would be adequate for even an AF camper and leave 2000 lbs. for water, food, toys, etc.
With a heavier class of truck the owner pays more to buy and maintain the truck, more in fuel costs, more in DMV fees, more expensive tires, and this only makes sense if it is absolutely necessary, or like Mitt have money to burn.
The 2011-2012 GM/Chevy 3500HD Crew Cab long box has a payload capacity of 5,905 lbs. and the 2WD version has a payload capacity of 6,223 lbs. Greatest payload is with the 2WD regular cab and long box at 6,635 lbs.
There are many class 3 duallys out there that don't have the 6000 lb payload capacity you are talking about. My F350DRW has about 4000 lbs payload capacity before it reaches it's 11,000 lb GVWR (truck weighs about 7200 lbs empty). It has about 5000 lbs rear axle load capacity before it reaches it's 8250 lb RGAWR (rear axle weighs about 3200 lbs empty).
SoCalDesertRider
Arizona desert
Posted: 04/27/12 09:29pm Link  |  Print  |  Notify Moderator
Americamper wrote:
I have noticed recently that most of the drugs advertised on TV have a disclaimer that they will kill you.
The side effects they list are worse than the ailment the drug is trying to cure.
ticki2
NH
Posted: 04/28/12 06:00am Link  |  Print  |  Notify Moderator
Those numbers are for truck only , no options , no passengers , no tools , etc.. Almost impossible to achieve . GM claims a curb weight of 7084# , have you weighed your truck ? Then deduct that from GVWR of 13000# . Anything older than 2011 will be down around 12000# or lower .
'68 Avion C-11
'02 GMC DRW D/A flatbed
serpa4
East Coast
Posted: 04/28/12 06:15am Link  |  Print  |  Notify Moderator
I had a 2006 AF, wood frame, 1150. Max weight was about 5,300lbs. I used it trouble free for about 3 years. I replaced the factory overload for a 5 pack of springs from Rocky Mountain Spring. Anyway, after selling the TC, I got to thinking the truck was riding stiff and sitting on the overload springs. After removal and finally comparing to new springs, the AF had literally bent my factory springs by a considerable amount. I stopped traveling with so much water and packed less. To be fair, it had full black and gray tanks.
Love the camping life. 06 Host Rainier SS, 07 Classic GMC Sierra 3500 DRW.
JIMNLIN
Oklahoma
Posted: 04/28/12 06:37am Link  |  Print  |  Notify Moderator
GM weight confifurator shows a loaded LTZ/Dmax DRW and as elkhorn says has 59xx lb load capacity.....
Current Selections: CC30943 -- 2WD Crew Cab Long Box with Single or Dual Rear Wheel, C7J -- GVWR, 13,000 lbs. (5897 kg) with diesel engine, LML -- Engine, Duramax 6.6L Turbo Diesel V8, MW7 -- Transmission, Allison 1000 6-speed automatic, 1LZ -- LTZ (1LZ).
Also a std cab DRW LT at 6885 lbs capacity....
For '11 GM raised their DRWs RAWR to 9375 from 8200-8500 RAWR to match Dodge 9350 RAWR and Fords 9000 RAWR.
GM online weight configurator is a excellent tool for figuring a trucks actual gross weights and axle weights for any optioned truck configuration. Much better than the estimating optional weights from a brochure.
mike740ski
Seattle
Posted: 04/28/12 09:36am Link  |  Print  |  Notify Moderator
Even the 2008-2010 F450 Pickup rating, although not close to the CC, aren't bad either. F450 Crew Cab Math (the last line is what it boils down to):
Tires / Dually spec: 23000 lb.
Axel spec: Fr / Rear = 7000 / 11000 = 18000 lb
Axel Vehicle rating w/ camper package: Fr / Rear = 6500 / 9500 = 16000 lb
Total GVWR rating: 14500 lb
"Combined weight of occupants and cargo should not exceed" sticker inside door: 5411 lbs
2010 F450 Lariat 6.4L 4X4 DRW 4.30LS 14500# GVWR. Camper Package. Torklift Tie downs Fast Guns Magnum Hitch Super Truss Extension Stable Loads Air Bags
2010 Lance 1191 Winter Package Onan Gen Dual Pane Windows
2006 Tige 22ve Wakeboard Boat
ticki2
NH
Posted: 04/28/12 04:27pm Link  |  Print  |  Notify Moderator
Interesting , why are the axle ratings lower with the camper package , or is that a typo ?
SuperDutyFiver
Long Valley, NJ, USA
Posted: 04/28/12 04:36pm Link  |  Print  |  Notify Moderator
If it's not a typo, then I'd imagine they drop the ratings to accomodate a higher center of gravity.
36' Carriage Carri-Lite 35rl3
PSD 4x4 Custom Tow Vehicle-the 550
PSD 4X4 2017 CC short box
PSD 4x4 SUV-the X
egarant
Mission Viejo CA
Posted: 04/29/12 10:38am Link  |  Print  |  Notify Moderator
Where did you find this GM weight configurator? Love to take a look at it!
Thanks!
2013 RAM 3500 Laramie Crew Cab 4x4 DRW HO Cummins/Asin Trans, 4.10's
2013 Eagle Cap 950
280 Watts Solar, 2K Watt Xantrex Inverter, Blue Sky MPPT Charge Controller, Lifeline Batt, Torklift Tiedowns/Superhitch, FOX 2.0 Performance Series Shocks w/CD adj.
Page of 9
