RV.Net Open Roads Forum: Class A Motorhomes: Overnighting at Tamarack in WV
 > Overnighting at Tamarack in WV
vfrmarc
Hamburg TWP Michigan
Posted: 04/24/12 08:07pm Link  |  Print  |  Notify Moderator
Does anybody know if over nighting is allowed at Tamarack on the WV Turnpike near Beckley?
They have a large bus/RV parking lot, we have stopped and shopped before, but can't remember if over night parking is allowed.
wny_pat
Western NYS
Posted: 04/24/12 08:35pm Link  |  Print  |  Notify Moderator
Yes, at least you could two years ago. You follow Vankirk Dr past the truck parking area and turn right onto Dickerson Dr. and turn onto the first terrace. You can park on the first lower terrace or follow it to the to the end and left swing onto second terrace.
If you look at Google Map, you will see what I am talking about: Go to http://maps.google.com/maps?hl=en&tab=Xl and type in the following: 37.800008,-81.217673. The green arrow is where you make your turn. It is tight!!! And also tight turning onto upper terrace. You should be able to make the turns okay with your rig, provided no one is parked in your way.
Oh, the food was not all that great. I had great hopes.
Eycom
32043
Posted: 04/24/12 08:43pm Link  |  Print  |  Notify Moderator
It has been a couple of years. But after using the Travel Plaza one night, I often used the Tamarak for an overnight spot. Averaged staying there or at the Wally World in Summersville, WV 8-10 times a year while traveling between the Carolinas and Pittsburgh.
RVn Full-time
OnaQuest
Old enough to be a
Posted: 04/25/12 05:45am Link  |  Print  |  Notify Moderator
I use the Beckley Cracker Barrel. Better food and quieter parking.
charles
Ohio
Posted: 04/25/12 07:10am Link  |  Print  |  Notify Moderator
Yes you can, but we found the first rest area in Virginia heading south was much more quiet.
Nick
2011 Vista 35F
zb39
slippery rock
Posted: 04/25/12 09:53am Link  |  Print  |  Notify Moderator
Just did it twice 5 weeks ago.
05 Tiffin Zephyr
07 Dodge Caliber toad
Artic Fox 1150 slide
2011 DRW 3500 Crewcab Longhorn
