RV.Net Open Roads Forum: Towing: Coupler Lock - what do you use?
Search only in Towing
Open Roads Forum  >  Towing
 > Coupler Lock - what do you use?
AtomicChicken
Central Louisiana
Posted: 04/27/12 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
I use a masterlock padlock. It's on the couple whether the trailer is hooked to the truck or not.
2007 F-150
2006 Sun Valley RoadRunner 240BH
Prodigy P2 / EAZ-Lift WDH
Huntindog
phoenix arizona USA
Posted: 04/28/12 04:18am Link  |  Quote  |  Print  |  Notify Moderator
I don't use anything as since I (like we all should) use a WD hitch.
The TT simply cannot come off the ball even if it is purposely unlatched.
Try it. hitch up like normal. Then undo the latch. Now try to get the coupler off the ball. Use your tounge jack, or a floor jack etc.
It simply will NOT come of the ball.
Huntindog
2010 Palomino Sabre 30BHDS
TWO bathrooms...No waiting!
MICHELIN XPS RIBS LRE
2011 Silverado Big Dually 3500 4x4 CC D/A
EQUALIZER Hitch
100% BOONDOCKING
Check out Rusty and her pups at www.bluecollarbrittanys.com
webslave
Clearville, PA
Posted: 04/28/12 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
When I had a bumper pull, I used a long hasp MasterLock resettable combination lock. Correct, with a WDH, it won't come off the ball, but, I used the lock anyway so that I would know where it is since I always locked the coupler when unhitched; a side benefit with the long hasp is that the 7-pin umbilical cord also fit into it...no way for the cord to get pinched or drag the ground.
My 2 cents, your mileage may vary...
Don
Bronwyn
3 Cats - Coco, J-Lo and Ragamuffin
2011 Keystone Cougar 318SAB
2011 Ram 2500 Longhorn CTD HO
Built in brake controller and exhaust brake
Tri Glide TrailAir Pinbox with a B&W Companion Hitch
rvaddict1420
Storage Lot
Posted: 06/18/12 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
ArcticDodge wrote:
I use a keyed masterlock padlock. I bought the four padlock set so all my locks use the same key. The other locks are used to secure bikes, genny, canoe, etc.
rvaddict1420
Storage Lot
Posted: 06/18/12 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
I am slow at looking at some of your posts so I am going to assume that you have already bought a coupler lock. If not look at the Coupler Vault by Megahitch Lock. I have never seen anything like this lock. I am a contractor with a enclosed cargo trailer that carries all my tools plus we have a travel trailer. I have had stollen my cargo trailer twice, and our travel trailer once in the last 10 years. I have tried severel different locks on the market. Nothing has worked or slowed down the thieves. I think the two new coupler vaults I have bought will do the trick. I already have had someone try to get it off and couldn't. I found the company online at www.megahitchlock.com. They have a video on the website showing them testing other locks. All of them were off the trailer hitchs in a matter of sec. to minutes. I am sold on the product and I would look into buying one if I was you. Even if you just bought a different lock. They will show you that it is worthless. Spend the money and get the best.
the_happiestcamper
Mount Pleasant, SC
Posted: 06/18/12 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
buzzard616 wrote:
I've used one of these PTO pins for years. You should be able to get them in the trailer section of any store that has one or a farm supply store.
Stu
X2
Jon, Freesi, Lars, Tucker, Holland
2003 Yukon XL 2500 8.1L 4.10 axle
2010 Dutchmen 28G-GS
CG's we've been to
LittleBill
Scranton, PA USA
Posted: 06/18/12 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
no offense but the video is a joke,
they put a lock bolt on one of the 2 hitch bolts. why not simply angle grind it off or use the sawzall and cut the bolt and remove the coupler completely like in the beginning of the video. i would have it off faster then all the cutting tricks they used
unless you have your coupler welded on...
