RV.Net Open Roads Forum: 2004 Dodge 2500 with 4884# of gravel in the bed *pics*
Search only in Tow Vehicles
 > 2004 Dodge 2500 with 4884# of gravel in the bed *pics*
ib516
Up here!
Posted: 04/25/12 05:20pm Link  |  Print  |  Notify Moderator
More pics:
Here you can see it's not quite on the jounce bumpers (look near the axle to the left of the spring)
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
DrBaker
Oklahoma
Posted: 04/25/12 05:21pm Link  |  Print  |  Notify Moderator
Looks like a lot of sag to me. I had a 2007 Ram 4x4 in white. It was super tall in the back end. That pic looks like he is dragging tail, IMO.
edit: looks like new pics were added as I was posting this.
2011 Chevy 2500HD CC/SB 4x4 Victory Red
2003 Crossroads Cruiser CF27RL
Champion Screamer, Reese 16k, and a Blue Status Symbol
boogie_4wheel
SLC, Utah
Posted: 04/25/12 05:22pm Link  |  Print  |  Notify Moderator
My dad and I did 6k worth of gravel in the back of his '01 Dodge (Cummins, ex cab, 4wd, dually). With dad and I in the truck it grossed 14.5k. It was squatting but was not near the bumpstops; wish I had taken pictures. You could tell it was back there. Of course it was on the overloads and even though it has the factory rear sway bar you could feel it lean some when changing direction.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer, ISSPro Oil and LP pressure gauges in cubby hole, GDP 20/2 filters on frame rail, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
gmcsmoke
Butler
Posted: 04/25/12 05:23pm Link  |  Print  |  Notify Moderator
MacRoadie
Orange County, CA
Posted: 04/25/12 05:32pm Link  |  Print  |  Notify Moderator
Ah, so now we have a better idea.
The 5,500 kg is the gross loaded weight (truck and gravel).
The 3,300 kg is the TARE weight (unladed weight of the truck).
With the better pics, it's much more obvious that the truck is not only down on the bump stops, but that the spring packs are almost inverted.
That makes much more sense.
2010 Chevy Silverado 2500HD, LT Crew, 6.0 Vortec, 4.10
2011 Keystone Cougar 26BHSWE
ib516
Up here!
Posted: 04/25/12 05:37pm Link  |  Print  |  Notify Moderator
Yes, at the top of the receipt, he came in at 3300 Kg (7260#), and left at 5500Kg (12,100#) = 2200 Kg (4840#) load. He does this regularly to repair his farm access road/driveway. He's only 3100# over his 9000# GVWR
CREATO
Beautiful Harvey N.D.
Posted: 04/25/12 07:30pm Link  |  Print  |  Notify Moderator
The cardboard put him over
I dont rent out space in my brain
coolbreeze01
Redding, Ca
Posted: 04/25/12 08:11pm Link  |  Print  |  Notify Moderator
Good 1, but if he adds side rails, he can haul a payload
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
bovellois
La Pocatiere Canada
Posted: 04/25/12 09:32pm Link  |  Print  |  Notify Moderator
ib516 wrote:
It's not sagging as much as I would have thought. It appears to be handling it just fine. He said it rode nice, and drove just fine with that load.
The CTD is on its best behaviour with a load like that. finally a bit of work.
Bruno, Carol, Thierry and Julien
Sankei the fox terrier
Starla the Gordon setter
97 Dodge 2500 4x QC diesel
2006 ROO19
rjstractor
Auburn, WA
Posted: 04/25/12 10:47pm Link  |  Print  |  Notify Moderator
Yes that load of gravel looks to be every bit of 5000 lbs. Being a 4x4 that truck will sit way higher when empty, probably 5-6".
I inadvertently loaded 5200 lbs. in the bed of my truck in my sig. The dump bed insert weighs 1000 lbs and I had 4200 pounds of gravel in the bed. My payload of my empty truck though is almost 4000 pounds, since my truck is a 2wd regular cab with a gas engine. With the dump bed I can carry 2700 without exceeding any of my ratings, and it drives and handles like a dream with that weight. I also once had 2 full pallets of sod in the back. Don't know what it weighed but was pretty scary to drive.
1998 Gulfstream Ultra B/H Ford E450 V10
2005 Chevy 2500HD 6.0 w/ Maxidump insert
2006 Ford Escape Hybrid
1998 Saturn SL2 toad
2012 VW Jetta S
