RV.Net Open Roads Forum: Airbags for DRW help eliminate CA highway bouncing??
Search only in Toy Haulers
 > Airbags for DRW help eliminate CA highway bouncing??
Page of 5
christopherglenn
a little over an hour from Yosemite
Posted: 04/27/12 08:45pm Link  |  Print  |  Notify Moderator
I put a Trailair pinbox on, It helped ALOT on the rear end bouncing up and down. Just added the tri-glide to help with the chucking, and have yet to go anywhere.
It is not cheap, but I would advise some sort of air hitch / air pin box.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Y-Guy
Tri-Cities, WA
Posted: 04/27/12 09:34pm Link  |  Print  |  Notify Moderator
Had airbags on our F350/Raptor combo and though I had them from the start. I didn't air up once and heading out of town I hit a spot that was bad on my previous setup and noticed it again without the air in, but when I was aired up it wasn't an issue at all. Just helps stabilize things and keep the truck level. Glad I had them.
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
1L243
Astoria, Oregon
Posted: 04/27/12 10:27pm Link  |  Print  |  Notify Moderator
Unless your hauling a cord of wood in the back of your truck I doubt if the weight back there makes that much difference by the time you get down that 39 feet to the garage...
I would suggest you weigh your truck empty by it's self, then loaded with all the wood and stuff in it then hooked up to the trailer both going loaded and coming home empty. This way you will know where you stand on weight...
If the bouncing on your truck is like Purposing kind of like going over rolling waves I think Air Bags would help. Throw on the airbags don't worry about a on board compressor. I ran the air lines out the rear by the license plate and air up with a portable air pump. You can play with the air pressure till you get the ride you like.
Air compressor has digital read out..
http://www.google.com/imgres?q=craftsman........p=15&ved=1t:429,r:0,s:0,i:69&tx=63&ty=40
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
kford131
Colorado Springs, CO
Posted: 04/28/12 08:40am Link  |  Print  |  Notify Moderator
I put a trailaire pin box on my trailer in Florida to remove the bounce, works great.
dfcfu342
Home
Posted: 04/28/12 06:03pm Link  |  Print  |  Notify Moderator
You can look into KYB Monomax shocks. They'll stiffen up the ride empty but loaded they provide great control of bouncing and wallowing.
Crazy Cooter
Redding, CA
Posted: 04/28/12 07:46pm Link  |  Print  |  Notify Moderator
If you are just off the overloads on the trip home, you could be bouncing off of those?
I have this issue when I am loaded in this sweet spot with 1/2" gap. I air up the bags a tad to open the gap a little and it smooths out.
If it is just a light valving issue with your OE shocks, the KYB Monomax's suggested above work great for the cost. If you are willing to spend a little more, the ProComp MX6's are adjustable mono tubes and work even better.
Tony KI6WAO
2006 Dodge Ram 3500 DRW
1992 Jeep Wrangler YJ
2012 Cyclone 300C
2013 Can Am Maverick X-RS
2006 KTM 525 EXC CA Plated
2008 KTM 525 XC ATV
2008 Polaris 525 IRS
2007 Kawasaki STX12F
2009 Kawasaki 260X
rasteck
Northern California/East Bay
Posted: 04/28/12 09:18pm Link  |  Print  |  Notify Moderator
The airbags made a noticeable difference for us. The worst stretch we've been on is 880 through Oakland and they helped a lot. Also getting both truck an trailer level when hitched up and EZ-Flex on the trailer has made a world of difference.
2000 Ram 2500 SLT/Laramie 24V CTD 2WD QCSB PacBrake, Smarty
2011 Colorado 320BS-FW 36'
EZ Flex + wet bolt
Curt E5 with R5 slider, Prodigy P3
Air Lift 5000's, Load Controller II
nayther
Burbank, CA
Posted: 04/30/12 10:29am Link  |  Print  |  Notify Moderator
The bags helped smooth out the ride on my '05 a LOT but that was because I was just barely touching the big overload spring and the bags got me off that and leveled the truck. The 2012 doesn't need them, trailer compresses the springs just enough to be level and it rides nicer than the '05 with the bags.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
mapguy
Puget Sound
Posted: 04/30/12 01:03pm Link  |  Print  |  Notify Moderator
This (frame level) and the comment about bouncing on/off the overloads are real important issues to tackle first before any kind of band-aid like air bags or cushioned pinbox.
If trailer nose high the rear axle pounding won't go away -period.
Trailer shocks and or cushioned equalizers are a must with trailers IMO. Any trailer builder that says otherwise is ignoring the physics involved in how a suspension works.
* This post was edited 04/30/12 05:10pm by mapguy *
sptrucksbyed
Bella Vista,CA
Posted: 05/01/12 07:59am Link  |  Print  |  Notify Moderator
Gordon2448 wrote:
I have a 39ft TH 3axle with a 14ft garage. That 14ft is behind the axle's carrying a RZR4 and 2 quads. Getting to where i'm camping, the rig drive great cause i have wieght (wood, water, ect) in the bed of the truck which equalizes the wieght. It is a different story when i come home because i dont have that wieght(wood, water ect) in the bed. Problem, when i hit big dips in our under funded CA highways, the rear axle of the truck bounces up and down "bad" because, of all the wieght is in the BACK of the TH and there lack of in the bed of TV. Question, would Airbags help lesson or eliminate the bouncing???
I would like to see a picture of how you fit all that in a 14' garage.
2012 Ford F-350 DRW CC 4x4
2011 Raptor 4014LEV
2 Yamaha Raptors
2 Yamaha Banshees
2008 Rhino
2011 RZRS
Page of 5
