RV.Net Open Roads Forum: Tow Vehicles: Dodge front driveshaft lube (R+R)
Search only in Tow Vehicles
 > Dodge front driveshaft lube (R+R)
ib516
Up here!
Posted: 04/28/12 05:58pm Link  |  Print  |  Notify Moderator
I read my OP again and just realized I didn't mention WHY you need to mark the driveshaft. In case anyone who reads this isn't aware, it's important that it goes back in the same way it came apart (matched up) to avoid vibration/balance issues.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
#40Fan
Colorado
Posted: 04/30/12 10:14pm Link  |  Print  |  Notify Moderator
I had to take a 6" grease needle and put a ~30* or so bend in it to get mine aligned properly. Then it was the three P's. Press, pump, pray.
While holding the needle on the fitting I watch for grease to start quirting out the rear of the joint.
2005 Keystone Outback Sydney 31RQS
2011 Ram 2500 CC LB CTD G56 3.42 Mineral Gray
ib516
Up here!
Posted: 05/01/12 06:42am Link  |  Print  |  Notify Moderator
mr. ed
Madison, SD (but usually elsewhere)
Posted: 05/01/12 06:33pm Link  |  Print  |  Notify Moderator
Here's a picture showing the lube point in the cardan joint. It can be difficult to find the first time but marking the location with white chalk or paint should make it easier next time.
Mr. Ed (fulltiming since 1987)
2007 Hitchhiker II LS Model 29.5 LKTG
2007 Dodge Ram 3500/6.7 CTD/QC/4X4/SB/SRW/6-speed man/Big Horn edition
Don & Linda
Western PA / Cape Cod
Posted: 05/02/12 12:03pm Link  |  Print  |  Notify Moderator
Hey ib516,
Great pictures, thanks for sharing.
I understand the value of the youngest son's moment to bond with dad, but if you want to stop wearing out your driveshaft's hardware, pick up a grease gun adapter made for tight places (cardan joints, some fwd axle joints) The pic below is a Lisle 90 degree adapter that screws onto the whip hose of a grease gun.
BenK
SF BayArea
Posted: 05/02/12 01:26pm Link  |  Print  |  Notify Moderator
Hey Don....ditto bonding with your kids...put a fond memory tear in my eye,
as mine are long gone and expecting my first grandson soon !!!!
Pride of ownership, maintenance, love of DIY'ing/helping/etc, and the big one
being the ability to not be afraid of doing anything...just learn the HOW2's
On your picture of that grease gun attachment...you lost me...how in the heck
does that thing attach and work????
Kinda sorta like the one where a huge bolt is obviously welded to
a nut and told to take that nut off...
Turns out the bolt has been cut and turns to come off, but the
other end has the nut welded to it...forces or shows thinking outside the box...
-Ben Picture of my rig
ib516
Up here!
Posted: 05/02/12 09:11pm Link  |  Print  |  Notify Moderator
Can you enlighten me on how that thing is supposed to work for greasing the front driveshaft lube point? I can't picture it. There's not much room in there.
Don & Linda
Posted: 05/03/12 04:40am Link  |  Print  |  Notify Moderator
Good Morning, Ben, ib516
Sitting here having my first coffee of the day, I tried to describe how it connects and after 2-3 wasted attempts (all seemed to confuse more than explain)
I decided the simplest way was to load Draw and make a simple diagram.
It slides straight onto the zerk. Locks in place with a click and requires a lil less than .250 clearance.
The back wall of the tube is a slotted teflon plate that keeps pressure on the ball of the zerk and the machined opening is just wide enough to keep it trapped while pressure lubing.
If my description helps, well that's good news. Now for the bad, I first thought it's mfg was Lisle, but now that I rethunk it, it could have been Mac, Alemite, KD, Cornwell, Matco, Snap-on...
Sorry, ole timers is becoming the rule of the day as well as KRS syndrome.
This style of adapter became popular in the late 70's and the last new one I purchased was from a mobile tool vendor in say... 2005/6. They do wear out after heavy use, but mine seem to grow legs long before then.
Edit: I just hate people who offer a different/quicker method, yet NO access info!
The Grease adapter is mfg by Lincoln Industrial Corp Lincoln Product Line p76-80
It's on p76 as Special Access Coupler Model 5883 90° Grease Coupler
* This post was edited 05/03/12 06:34am by Don & Linda *
Sorry if this post seems long, I lacked the time to make it shorter.
almost quote from S.L. Clemens
Don & Linda
1st RV UL EMS 4s Dome
2nd RV 21' AMF Scamper TT PV D300 Dodge
3rd RV National Seabreeze 133LX w/Demco Dolly
4th RV Jayco 2450 5TH PV Ford F-250 SD
ib516
Up here!
Posted: 05/03/12 06:43am Link  |  Print  |  Notify Moderator
That'd be great if there was a zerk. There isn't though, just a small dimple.
Don & Linda
Posted: 05/03/12 07:51am Link  |  Print  |  Notify Moderator
ib516 wrote:
Wow, your jpg sure looked like the joint had a zerk fitting, must be an optical illusion, Sorry just tried to help. I'd follow the above posters advice with the bent lube needle. Still better that dragging the drive shaft out.
