RV.Net Open Roads Forum: Toy Haulers: Gas Tank making noise.
Search only in Toy Haulers
 > Gas Tank making noise.
tmm2good
Arvada, CO
Posted: 04/28/12 08:57am Link  |  Print  |  Notify Moderator
I thought i read about it once before, but I could not find the topic. My first time with an on board gas tank, I can hear the tank popping wile it expands and contracts while I am running the generator or with temp changes. IS this normal? Should there be some kind of venting? When I open up the gas cap you can hear the pressure being released and the tank expanding.
13 GMC Denali Dually D/A
12 Keystone Fuzion 301
04 Kawasaki KFX700
05 Raptor 350
08 Kawasaki Concours 14
06 Kawasaki KLX250 - dual sport
eHoefler
ozark mountains
Posted: 04/28/12 09:42am Link  |  Print  |  Notify Moderator
Due to emissions, gas tanks can not free vent any more. The popping is normal.
2010 Ram 3500, Crew Cab, Long bed, 4 x 4,Dually, Lights & Siren!
2006 40' Landmark Mt. Rushmore
2oldman
Winchester WA
Posted: 04/28/12 10:14am Link  |  Print  |  Notify Moderator
I find it hard to believe you generator can even run if the tank is not vented.
fj12ryder
Platte City, MO
Posted: 04/28/12 10:17am Link  |  Print  |  Notify Moderator
If they can't vent, why don't the tanks collapse when emptying? You got me wondering as I have a gas tank but haven't used it yet.
Howard and Peggy
"Don't Panic"
christopherglenn
a little over an hour from Yosemite
Posted: 04/28/12 10:19am Link  |  Print  |  Notify Moderator
There HAS to be a vent, the generator fuel pump can's pull a vacuume in the tank. I assume they all have charcoal canister now a days just like cars.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
midnightsadie
ohio
Posted: 04/28/12 03:44pm Link  |  Print  |  Notify Moderator
alot of gas caps have a vent built into the cap, might check this out.
danojeno
Corona, CA
Posted: 04/28/12 03:48pm Link  |  Print  |  Notify Moderator
I would find the vent hose and verify that it is not kinked or plugged.
2006 Chevy 2500HD 8.1 4x4 CCSB
2012 Eclipse Stellar 28SBG, Spring Over Axle
eHoefler
ozark mountains
Posted: 04/28/12 03:50pm Link  |  Print  |  Notify Moderator
They vent one way,in. That is why you have pressure when removing a cap to refill. On todays vehicles, if the gas cap is left loose or not on at all, in most cases, it will set a check engine light and fault in the ECM.
lincster
Mesa Az
Posted: 04/28/12 03:56pm Link  |  Print  |  Notify Moderator
Yep, been discussed on here a few times. Popping is normal with running or temp changes.
2012 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
tmm2good
Arvada, CO
Posted: 04/29/12 08:49am Link  |  Print  |  Notify Moderator
Thanks for the feedback. Knew it had been discussed before. Just got to get used to it I guess.
