Still thinking about buying a tank for extra diesel fuel.
Is the cost the same for similar size tanks? Of course there is extra equipment on the transfer tank, just saying if all else is equal which one is cheaper.
Money's real tight, eldest daughter getting married in about 2 weeks & youngest moved back in and is going to college in fall.
2012 Cedar Creek 36RE w/ Level Up
B&W Turnover w/ 18k Companion Hitch
08 Ford 350 Lariat DW PSD Crew Cab Long Bed 4:30
Price will vary based on size and design. Check out Northern Tool to look at some different sized and style models. I have the 90 gallon RDS with tool box and its perfect for me.
There are many used tanks around these days too-people downsizing out of trucks and people upgrading to a new tank for their new truck! ANyhow-I'd check out ebay and craigslist if you're looking to save some bucks...(new lines and a solenoid are my one fix to suggest! and maybe a bottle of AL polish if you don't go steel)
My $500, 91-gallon RDS tank from Northern Tools can be used for either. It has ports on the top and bottom for either connecting it to the truck's fuel system (bottom port) or to install a fuel transfer pump and hose (top port), or both simultaneously.
In my case, I use the tank's top port with a 13-gallon-per-minute fuel transfer pump equipped with two filters and a gauge to keep up with gallons being pumped.
