nana2callie
Arkansas
Has anyone done this and do you think it is necessary or overkill?
thanks
brirene
midwest
Hmmm, never really thought about it, but then usually have kids sleeping there, if necessary, and never had a problem. I guess it would depend on what type of weight you plan to have on it. I personally don't think its necessary.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
SJR
Philadelphia, PA
Yes I would, and have done it. The table is only made from particle board and WILL warp after time.
Stephan
2010 Dodge 2500 Crew Cab
2003 Northstar TC800EC
2003 Jayco Kiwi 21C
Equalizer Hitch
Charltons
Battle Ground, WA
I suppose it would depend on how often you plan on using it. On our last TT we used it all the time for the Kids friends and never had a problem. (very little weight) If you were going to have adults sleep on it all the time I think I would look into doing some reinforcing.
2012 Dodge Ram 2500 Crew Cab 4X4 TCD
2012 Keystone Sprinter 311BHS
concord32
Indianapolis
I plan to. Mine is made out of molded fiberglass. No way I would use it for a bed till I get it done. I plan to use 3/4 ply for mine. Enough room under it so it wont show.
2011 Coachmen Concord 32' Triton V-10 1-slide.
skipnchar
Topeka or somewhere else
Like many things, it depends on the details. Depends on how stout your table is before reinforcing it and who is sleeping on it (size wise). Usually the bed is occupied by smaller children but for weak tables and heavy adults things may be different. I doubt if the table in my Jayco pop up would support larger adults for very long because it barely supports itslef (warped badly enough that it is necessary to find something to LEAN a coffee cup against at breakfast time
lots2seeinmyrv
Ocean Springs, MS
Do you have the 4" round table legs with the round anchor posts on the floor and under the table?
We made 2 "short" legs out of PVC pipe and used those as support when the dinette was made into a bed.
2010 Tundra TRD 4x4 Dbl Cab 5.7L V8 4.30 Max Tow 10,300 Payload 1,640 Class IV Hitch 1,030
Prodigy P2 - Blue Ox Sway Pro 10K/1K lbs
2012 Evergreen Ever-lite 29FK
Merrykalia
Appalachian (apple at chun) Mountains in SW VA
When we had our HTT, DH took the table and used it as a pattern and cut one from 3/4 plywood. Finished it by sanding and poly. He also put another "leg" undernear the middle back and front using a piano hinge. We cut a spot out of the middle so the table leg would fit in. It worked great and DH is a BIG, BIG man - 6'3, 340.
CincyGus
Cincinnati
lots2seeinmyrv wrote: Do you have the 4" round table legs with the round anchor posts on the floor and under the table?
I have not yet but have plans to use 2" stiff PVC and make the frame of a box whose height is perfect to support the botton of the table. this should prevent any warping when I use it for adult guests. Should be about a $20 project.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
westend
all over
My '72 Starcraft has two metal stiffeners screwed into the underside of the table. The table is still straight at 40 years old.
'03 F-250 4x4 CC
