RV.Net Open Roads Forum: Class A Motorhomes: F53 Flexible Brake Hose Replacement procedure?
 > F53 Flexible Brake Hose Replacement procedure?
Page of 5
OnaQuest
Old enough to be a
Posted: 05/02/12 05:04pm Link  |  Print  |  Notify Moderator
John&Joey wrote:
Pirate wrote:
My 97 Ford Class A had nothing but brake problems from day one. My repair man suggested the brake hose issue. Changed them, no more problems. He cut one apart, yes, it was swollen shut in the middle.
Thanks for the input.
I'm really surprised that Big K hasn't stepped into the thread. He went thru all of the suggested fixes and never fixed the problem until he bought a DP.
Nothing wrong with PM that's for sure. If the hose does fix the one heating brake please post back. If everything else is serviced, then that would be the end answer. If once the hose was off could you also please do the cut apart and photo for the rest of us to see.
There's your answer... Buy a DP
Seriously, I'll post the results when I get the hoses changed.
96Bounder30E
America is my home!
Posted: 05/02/12 05:31pm Link  |  Print  |  Notify Moderator
Lou,
I too would love to see a picture of that hose cut open..........being my chassis is a year older than yours I might have to follow your lead......
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
OnaQuest
Old enough to be a
Posted: 05/02/12 05:54pm Link  |  Print  |  Notify Moderator
Okay, Eric, John and Joey. Let's meet at my house tomorrow morning at 9am, and when you've helped me get this darned hose off, we'll cut it apart and post photos of it.
George Beggs
Homosassa, FL.
Posted: 05/02/12 06:03pm Link  |  Print  |  Notify Moderator
OnaQuest wrote:
Can anyone tell me exactly how to remove (& replace) the flexible front brake hoses on the 1997 F53 chassis?
I was able to remove the clip at the frame rail connection point, but can't decide what has to happen next. Does it unscrew? Pull off? What?
As you might imagine, it's too rusty to tell exactly how it connects. There are two flat sides on the hose metal connector, but they don't look to be designed for using a wrench.
There is a frame cross member and other "stuff" directly behind the rail so it's difficult to see of feel back there to determine what may be required. Any help would be appreciated. lou
I can't; but you might find the help you need on the iRV2.com/forums on this link. It looks like Lt46 knows how.
George & Linda
1999 Pinnacle F53 6.8L V10
Banks Transcommand
OnaQuest
Old enough to be a
Posted: 05/02/12 07:52pm Link  |  Print  |  Notify Moderator
Thanks, George. I saw that thread today and it gave me hope that it can be done. I'm just not sure I'm flexible enough to get my hands into those tight places, or with enough strength to get the job done.
I do plan to have the hoses in hand before I proceed, in the event I have to destroy the hose in the removal process.
Thanks again, lou
John&Joey
Some Location
Posted: 05/03/12 08:51am Link  |  Print  |  Notify Moderator
It's a deal, I'll even buy the first round.
Right now I'm on the road and can't post the picture of my '96 F53 up on jacks with all four tires off due to the calipers sticking from an emergency stop I had to do in Florida so as not to hit a couple of bikers that cut me off. That was my first year with the rig, and since then I have greased all the pins, then replaced all the calipers and also the fluid.
So needless to say, this topic is near and dear to my heart, that's why I'm asking so much.
RLS7201
Some Where
Posted: 05/03/12 10:03am Link  |  Print  |  Notify Moderator
How about one of you 96 F53 owners (hint hint Eric. GRIN) go look at a front brake hose and tell us if it looks like picture 1 or 2............Inquiring minds want to know.
Richard
95 Bounder F53
enblethen
Moses Lake, WA
Posted: 05/03/12 02:08pm Link  |  Print  |  Notify Moderator
I don't have Ford, however my Chev chassis differs from side to side.
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
96Bounder30E
America is my home!
Posted: 05/03/12 04:38pm Link  |  Print  |  Notify Moderator
OK RLS7201........for the record........here is what the brakes fittings look like on a '96 F53 chassis.......
Lou, Sorry I couldn't make it to your brake line party.......I had promised my wife today was my sock drawer cleaning out day
bluebirdPT36
NE Tn
Posted: 05/03/12 05:17pm Link  |  Print  |  Notify Moderator
I had to replace the hoses on my old 1978 Ford pickup. Even though the fitting nuts were in plain view and I have the proper line-nut wrenches, I could not get them loose. I did not want to wring them off. I heated them with a propane torch and they then removed quite easily. WARNING: have water hose ready if you try this.
Can you get to the nut with a crowfoot-linenut wrench? Not sure, but would think that Harbor Freight has them.
Page of 5
