Gator48
Branford
I just did an oil change on my generator using spec oil, and after the fact started to wonder if Synthetic would have been better.
Any input?
Artum Snowbird
Campbell River, B.C., Canada
I use synthetic blend in all my motors, lawn mower, pressure washer, generators... I like that it's better and most of those devices don't have oil filters.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
Effy
MD
Since the gen takes such a small amount I use Royal Purple.
2012 Thor ACE 29.1
Hawkeye10
Payson Az
Just changed my oil and filter today on my Onan. I use Mobil 1 synthetic on the generator and the coach motor. I think it is worht the expense for the added protection.
The Texan
Meridian, Idaho
Ours has had nothing but synthetic since the initial oil change when it was new. Just had it serviced at Speedco with Rotella T-6.
Bob & Betsy(FishNFanatic) - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
'05 HR Endeavor 40PRQ, 400 Cummins-Pulling our '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2010 Rzr or 01 V Star in back.
Where the wheels are stopped today
wolfe10
Hawkeye10 wrote: Just changed my oil and filter today on my Onan. I use Mobil 1 synthetic on the generator and the coach motor. I think it is worht the expense for the added protection.
If a gasoline or propane generator that's great (if the proper viscosity).
But, if a diesel, read carefully on the bottle/can to verify that it IS for diesels/meets the mil specs of you diesel.
The two oils are not necessarily the same!
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
doubleG
OC,MD
I use what it came with and I think it was Mobil Blue Syn. Onan 10KW
zman-az
Northern AZ
mci7 wrote: Recommended lube oil is a good quality 15W-40 Like Shell Rotella, or any other quality oil. If you feel better using the synthetic, by all means do what makes you happy, it only costs a few bucks more. For me, it is a total waste of money, but everyone has an opinion for sure, why I recommend, Do what makes you the happiest.
Dave
On the same line here. I know of alot of engines with well over 200,000 miles on regular oil. Changing the oil and airfilter on a timely basis is more important.
I do like sythetic in tranny's and as a mix in my 2 stroke stuff. Only because you rarely change tranny fluid and with the 2 stroke you actually burn the oil and its cheap.
As far as your generator, it may be worth it as it does not take much oil but I would just wait until your next oil change to put it in.
mci7
Virginia
Dave
